Official DTR Members "Twins" Club
Old Mar 4, 2008 | 10:20 AM
  #316
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by jrussell
There's a simple solution to the W/G issue on the stock turbos. You can drill a hole in the divider and then all 6 cyl will be the same.
I don't really see it as that big a deal. The overall power of the new tune probably won't be much more than the current #9 stacked with a pressure box. The stocker-based twin setups have no problem keeping up with that stack.
While that may/may not be true, we are not simply discussing power-- 5-600 hp is 5-600 hp at any RPM... the problem to keep in mind is exhaust airflow! At every single rpm the engine has 360ci of displacement of air to move. As we go up in rpm and power, that amount of air goes up much more than simple displacement at an exponential rate due to boost levels (cramming more air in)and expanding exhaust gases. Our CTD's were designed for a certain mount of airflow and is most efficient between 1700-2300 rpms. At 4000rpms, you are looking at an exhaust airflow that is much, much more than a simple doubling of rpms. The corresponding drive pressure could go through the roof! And even if drilling between the EH divider helps to equalize the pressure between cylinder banks (1-3 vs 4-6), you are now left trying to cram 2x as much flow through one wastegate designed for a much smaller airflow requirement.
Having said all that... there is the corresponding pressure on the compressor side to keep up and in improperly/under wastegated turbo set-ups, this could lead to overspeed situations and failed turbos.
Old Mar 4, 2008 | 12:24 PM
  #317
jrussell's Avatar
Makes sense if you're talking about running significantly higher RPM's. For those who don't choose the 4k RPM option it won't be a problem though.
You have to remember that most of us currently running the Smarty are seeing 3400-3500 RPM's between shifts. The 4k option is really only about 500-600 RPM higher than what we see now. I'm not saying it won't cause DP issues for some of us...I guess all we can do is wait and see.
Maybe Nathan has some insight for us?
Old Mar 4, 2008 | 02:06 PM
  #318
soulezoo's Avatar
DTR 1st Sergeant
You know, Omaharam ran the TNT with just an Aurora 3K... and that is unwastegated and he made 648 I think. I can't imagine what his drive pressures and air temps were.
You are correct about the 3400-3500 on the smarty now, that is what I see as well... I just imagine there are many of us where that is the threshold or maybe even already over a little.
You are also correct: "We'll see!" I can't wait myself!
Old Mar 4, 2008 | 02:21 PM
  #319
TXCTDSweetheart's Avatar
I want to join the Twins club, what number am I??..........#32??
Old Mar 4, 2008 | 02:45 PM
  #320
soulezoo's Avatar
DTR 1st Sergeant
Yes, you can be #32.... welcome! and feel free to use this thread to discuss anything relating to the world of twin turbos.
Old Mar 4, 2008 | 07:03 PM
  #321
Luvnacumns's Avatar
Nope he didn't have the TNT.. Unless this was recent I talked to him last week and it was not the tnt tune.....
Old Mar 5, 2008 | 08:45 AM
  #322
soulezoo's Avatar
DTR 1st Sergeant
Please welcome Desertchecker as twins club member #33!!!
Old Mar 5, 2008 | 08:48 AM
  #323
soulezoo's Avatar
DTR 1st Sergeant
No, this has been a little while now. I may have reached a little calling it the TNT tune he used, but what he got to try was the early development of that tune before it was called such...at least that is what I was infomed of. It was certainly more wicked than the beta tunes!
Old Mar 5, 2008 | 08:49 AM
  #324
soulezoo's Avatar
DTR 1st Sergeant
1.Soulezoo
2.JRussell
3.Cquestad
4.04 Smoker
5.PTGarcia
6.Luvnacumns
7.Snoxracer
8.Dodge 359
9.3500lly
10.gsdog1
11.DWiggs
12.CTD06
13.OT-OF-Here
14.bnold
15.mudslinger
16.dieselram04
17.John_P
18.banshee69
19.jbjarko
20.BlueDragon USMC
21.Whada
22.Dodgezilla04
23. 94ttss
24. rams-n-hogs
25. Sloverado
26. BBA
27. trefling
28. Sapps
29. Morse
30. bluechrome
31. jaredb900rr
32. TXCTDSweetheart
33. desertchecker
Old Mar 5, 2008 | 08:11 PM
  #325
Luvnacumns's Avatar
Yep I believe he called it a "custom" tune!!!
Old Mar 21, 2008 | 10:31 AM
  #326
molalla1ton's Avatar
I would like to join "the club" is that #34?
Old Mar 21, 2008 | 11:09 AM
  #327
soulezoo's Avatar
DTR 1st Sergeant
That would be correct! and welcome!
Old Mar 21, 2008 | 11:10 AM
  #328
soulezoo's Avatar
DTR 1st Sergeant
1.Soulezoo
2.JRussell
3.Cquestad
4.04 Smoker
5.PTGarcia
6.Luvnacumns
7.Snoxracer
8.Dodge 359
9.3500lly
10.gsdog1
11.DWiggs
12.CTD06
13.OT-OF-Here
14.bnold
15.mudslinger
16.dieselram04
17.John_P
18.banshee69
19.jbjarko
20.BlueDragon USMC
21.Whada
22.Dodgezilla04
23. 94ttss
24. rams-n-hogs
25. Sloverado
26. BBA
27. trefling
28. Sapps
29. Morse
30. bluechrome
31. jaredb900rr
32. TXCTDSweetheart
33. desertchecker
34. molalla1ton
Old Mar 21, 2008 | 11:14 AM
  #329
Dodge359's Avatar
Anyone have any leads on a 22 or 23cm turbine housing for a 3b? Hoping that will solve my egt problems?
Old Mar 21, 2008 | 11:21 AM
  #330
soulezoo's Avatar
DTR 1st Sergeant
Pretty sure PDR has them in stock for around $200.
