now i have trans and smarty what else should i get for towing
Old Sep 6, 2008 | 08:56 PM
marlbroman's Avatar
i tow 10k plus about 80 percent of the time.my truck is the 235hp version and i want it to tow a lot better.what are some good set ups to go with
Old Sep 6, 2008 | 09:04 PM
t-boe's Avatar
I'm thinking a turbo or two. If you've got the cash go for twins. You'll be able to run the smarty on higher settings while towing.
Old Sep 6, 2008 | 09:08 PM
trx's Avatar
trx
Air bags made a big difference for me. No more sagging rear end.
Old Sep 6, 2008 | 09:23 PM
marlbroman's Avatar
i will have to stick with a single turbo
Old Sep 6, 2008 | 09:41 PM
t-boe's Avatar
If you don't plan on anymore mods a htt 62/65/12, 13ss or 14 would be good. Maybe a 62/71/13 if you want a little more cooling. Nice thing is you can get them from Lary at the DTR store for a decent price.
Old Sep 6, 2008 | 10:45 PM
shortbed rv's Avatar
One of the best mods I made for towing( 13k) in the mountains is a rear sway bar. I have a short box if you have a dually then you probably ok. check out Al Corr sway bar and air bags.
https://www.dieseltruckresource.com/...light=sway+bar
Old Sep 6, 2008 | 11:21 PM
marlbroman's Avatar
yes i could use both those items.im still looking for more power as i am lacking in that department.
Old Sep 6, 2008 | 11:29 PM
Spooler's Avatar
If you want more usable power a turbo and lift pump is in your near future. Just be very careful what you buy. Twins would be best, but a 62/65/13ss would be good.
Old Sep 6, 2008 | 11:31 PM
no_6_oh_no's Avatar
Definitely a turbo, the stocker is less than adequate for what you want. A pressure box like an EZ or TS MP will work nicely with the Smarty and give the engine good kick. A set of 25 or 50 HP injectors will help also.
Might want to consider a fuel system upgrade also.
Old Sep 7, 2008 | 10:44 AM
ShutupAndHoldOn's Avatar
If you get near any mountains an engine brake is a must have!
Old Sep 7, 2008 | 01:40 PM
wimpy76's Avatar
Im running a HTT 62/14,Smarty,GDP392, and pull a 11k trailer in the mountains not flat ground and have plenty of power. During the summer EGT's can get high on 10% grades but, I still have plenty of power.
Old Sep 7, 2008 | 01:42 PM
marlbroman's Avatar
i have a pac brake i will add that to my sig.all i do is tow up and down hills.
Old Sep 7, 2008 | 01:45 PM
marlbroman's Avatar
how bought the super b turbo.that way i can up grade latter.
Old Sep 7, 2008 | 02:25 PM
tcr's Avatar
tcr
X2, air bags are great for towing heavily.
Checkmate
Mar 2, 2008 12:50 PM
LanceD
Feb 6, 2008 05:28 AM
White97GTVert
23
Aug 1, 2007 08:11 PM
tywebb3
Jun 23, 2006 11:30 PM
Puke
May 22, 2003 12:18 AM
