Is this normal EGT's??
Old Jul 24, 2006 | 09:45 PM
dodge2005's Avatar
Question Is this normal EGT's??
Well, I have been towing my friends 22ft steel Hewes fishing boat (4000lbs) and I seen my EGT's slowly creeping up 1200 to 1350 at times during the climb up the mountain. Boost is low around 5-6psi, box set to level2, traveling about 55 to 60 mph. When the truck down shifts during the climb, boost is goes up 25 to 30 psi and the EGT's start to go down to around 950 to 1000. The boat with full load with all the camping/fishing gear maybe weights total 5000lbs, I am guessing.
1. Now I am wondering if this is normal.
2. At what EGT temp should I get concerned when towing with my current setup?
3. Why does the EGT's go down when downshifting during a climb with the RPM's @ around 2100?
4. I would not think my EGT's would get this high with this kind of weight am I wrong?
5. Should I consider aftermarket goodies to low my EGT's a little more?
Thanks
Old Jul 24, 2006 | 10:01 PM
bigman's Avatar
Sounds normal to me. Your egts drop at 2100 rpm because your turbo is pushing more air to burn the fuel. Low boost = higher egts. Most folks say 1300 sustained is alright. If i pull a really long hill 1250 is my max. The best way to lower egts is a free flowing exhaust, complete air intake and or larger turbo. Remeber that the higher in elevation you go, the less air there is and egts rise alot faster. Your friend here is more boost! Good luck!
Old Jul 24, 2006 | 10:28 PM
1fstdsl's Avatar
Low RPM, Low Boost, Load/Grade = High EGT
Old Jul 24, 2006 | 10:46 PM
StrokeThisCTD's Avatar
those are normal EGT's. when you hit 1450 then you should be backing down. you can sustain 1450 degrees for extended periods of time. If you have to spike higher degrees going up hills, then dont be scared. Your EGT's are normal.
Old Jul 25, 2006 | 12:54 AM
973604x4's Avatar
sounds good to me...UNLOADED with just an EZ on my truck on level 3 i could hit 1500* no problem.
Old Jul 25, 2006 | 04:34 AM
dodge2005's Avatar
Thanks for lowering my concern!! So more boost it is!!!
marc03
Dec 24, 2005 09:10 PM
jmd025
Dec 14, 2005 07:58 PM
t_george77
Nov 23, 2005 02:19 PM
swansong04
Feb 19, 2005 11:19 PM
northern puffer
Dec 23, 2003 09:00 PM
