no locking hubs
Old Mar 17, 2005 | 11:17 AM
James Birdsong's Avatar
no locking hubs
I have a 2004 2500 4X4. Can any one tell me why they do not use locking front hubs? has any one tried installing them?
Old Mar 17, 2005 | 11:35 AM
CTD NUT's Avatar
Not that it matters much in this case, but you should post in the 3rd gen forums for questions pertaining to 03 and later CTD's......and fill out your sig so we know exactly what you are driving.
Because of the silly spindleless front wheel bearing assembly that Dodge uses, there is no practical way to add locking hubs since it is only a semi-floating axle assembly instead of full-floating. I know for 2nd gens Dynatrac offers a kit that converts the D60 front to 35 spline inners with the option of 35 spline outers and converts the frontend to a full-floating arrangement with spindles......this system uses manual locking hubs. These kits are not cheap and are considered a heavy duty upgrade for offroad use......I am not certain if a similar kit is offered for AAM axles on 3rd gens....but if it isn't, I would not be surprised if Dynatrac is working on it.
Old Mar 17, 2005 | 01:23 PM
tool's Avatar
I am currently in the process of getting royally screwed for a front hub job at an area shop/ used truck dealer.
I had enquired about converting to a manual hub setup and contacted Warn and some others and had no luck. Decided to just stick with the stock setup.
Old Mar 17, 2005 | 01:32 PM
mkubacak's Avatar
Second Gens can use this setup.
http://www.dynatrac.com/dodge-hub.htm
Pricey but some may feel it is worth it.
Old Mar 17, 2005 | 10:20 PM
Nevada's Avatar
All third gen 4 x 4's come with locking hubs, but they do not come with un-locking hubs
Old Mar 18, 2005 | 04:42 PM
Kanab Ram's Avatar
Dynatrac is working on an unlockable hub setup for 3rd gens. There is a group buy and other information on TDR. I was one of the ones who gave dynatrac my truck for a few days to engineer something. I believe they are getting close.
91oldranchtruck
Jan 31, 2011 09:45 AM
falcondan9570
21
Aug 12, 2004 01:17 AM
squirlchasr919
19
Aug 4, 2004 10:39 AM
JMCOOPER
May 28, 2003 01:20 PM
Nuttymopar
Apr 5, 2003 08:13 PM
