3rd Gen High Performance and Accessories (5.9L Only)Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 5.9L ONLY!
Go with a 2 stage setup. I researched alot before putting on my truck and a couple of smaller shots close together is WAY easier on parts than 1 big shot. It will only cost a couple hundred more but is well worth it. And watch the drive pressure as has been mentioned.
That is partly correct....the reason 2 shots is better is because you can run the small one sooner than 1 big shot. Then the 2nd shot comes in later. Plus this allows you run 1 shot pre-CAC, this produces more power due too the cooling effect....AND prevents snuffing out the fire because it gives the nitrous more time too accept heat from the surrounding air.
Originally Posted by blwnsmke
Well you know your stuff.. Whats a good shot to start at and what size should you start really being careful? Is a 100-125shot dangerous or being risky on a diesel?
Diesel Nitrous systems should not be labelled like a gasser system. A .046 jet may produce 100hp in 1 truck and 160hp in the next. All depends on the amount of extra fuel, where the jet is placed, and a couple other factors.
