nitrous yes or no
with the mods that i have can i spray any nitrous 35 or 50 shot and be safe
I would think so, im spraying a 105 shot with my mods!
any more info for me guys
I think you need studs first
I ran my system without studs a few times and 50 psi boost, never had a problem
that little you should be allright anymore I would really consider studs. Stock internals will be fine no need to worry about them.
Stud it then I would spray it bullydog is adding lots of timing and then your adding more with nitrous. I wouldnt be considered with boost as much as I would be with cylinder pressures. Then your turbo will be the weak link due to drive pressure if you go with a 100+ shot but with a small shot should be fine imo after you get some head studs. Prevention is alot easier then cleanup, just what ive been told [laugh][laugh].
I thought of spraying my truck but ive heard so many bad things of dropping valve seats and blowing head gaskets I dont want mass destruction. I just wanted like 100hp shot or so not huge amounts
I too planned on spraying mine in the future but am scared to tear anything up
I have been told mild shots 50 to 70 actually help lower EGT's?
Yes, N2O does reduce EGT's. When you spray it, its in liquid form. N2O boils off at -129* so its extremely cold when it changes from liquid to gas. Thats why when you spray too much it shuts down your engine. It gets so cold the fuel cant ignite, so no flame. N2O is some pretty good stuff when used correctly. Its like anything else, when abused it will cause damage and therefore gets a bad rap. Start off small and work your way up, it will be alright [guitar]
Originally Posted by matego
(Post 2108482)
Go with a 2 stage setup. I researched alot before putting on my truck and a couple of smaller shots close together is WAY easier on parts than 1 big shot. It will only cost a couple hundred more but is well worth it. And watch the drive pressure as has been mentioned.
Originally Posted by blwnsmke
(Post 2108506)
Well you know your stuff.. Whats a good shot to start at and what size should you start really being careful? Is a 100-125shot dangerous or being risky on a diesel?
gotcha.. I plan on doing injectors and turbo soon. Just not sure if I wanna try twins or single
