Need some fast helpon fuel pres. gauge install (banjo location)
Old Mar 24, 2006 | 07:39 PM
barracuda's Avatar
Hello All, I am in the middle of the gauge install on my 06' and the only thing to complete is the hook-up between the isolator and, well, at least what the instructions are telling me, the bottom of the fuel filter canister?? is this right? got em' from Diesel Manor (very complete set by the way) but am I looking at this picture correctly? the bottom of the filter canister? Thanks
Old Mar 24, 2006 | 07:44 PM
barracuda's Avatar
Actually it isn't a Banjo bolt, just a 90 degree brass fitting...Sorry
Old Mar 24, 2006 | 07:53 PM
barracuda's Avatar
OK, I need a beer, it's not the 90 degree fitting, it actually goes through the existing Banjo (has holes in it) from the bottom of the fuel canister. Still though, is this OK? (now that i confused everybody)
Old Mar 24, 2006 | 08:47 PM
MoparRiggan's Avatar
I did mine on my 05 and I installed the isolator on the side of the battery tray by drilling to small holes and using sheet metal screws.
The kit you have should have a banjo bolt with a threaded hole in the top of it.
I mounted my banjo bolt with hole in the top of the CP3 Pump -(follow the line from the bottom of the fuel filter housing over to the CP3 pump)
It is fine at the CP3 OR at the bottom of the fuel filter housing. I just like knowing what the psi is at the CP3 pump.
Old Mar 24, 2006 | 08:48 PM
HP Upgrades's Avatar
Go grab us another beer. At this rate you will have it all figured out soon so we can check it when we go get more beer!
Sound like your on the right track. Cheers!
donhov
Aug 9, 2010 12:50 PM
jmccart
Jan 26, 2008 07:36 PM
59FORD
Apr 7, 2006 12:28 AM
CTD_Neil
Mar 22, 2005 03:24 PM
chucktownsend5
Jan 19, 2004 03:20 PM
