need long travel airbags, where to find?
Old Aug 15, 2009 | 11:49 AM
txarrowhunter's Avatar
I have a 5" susp lift with 6" revtek coils on the front its perfectly level now with an 1/8" diffrence center to center in the front. Where can i find some long travel air bags for towing i know that when i hook up the flatbed with my sandrail's and ranger its gona squat.
Old Aug 15, 2009 | 08:14 PM
So is there a kit for 5" lifts or should I get add aleaf's or packs. Sureley someone has a name for longer air bags.
Danderson's Avatar
Sage Carli sells long travel airbags for his 3" suspension lifts. You might call and talk to Jesse or better yet Baja Mike. www.thecarlisuspension.com
Old Aug 15, 2009 | 11:55 PM
Mocho's Avatar
You don't need any special air bags if you've got factory leafs. You just get the Firestone ride rites, they mount to the frame and leafs.
Old Aug 16, 2009 | 12:39 AM
WhiteMule's Avatar
Is there a reason for not using the air bag spacers under the "normal" air bags such as the firestone ride rites if you don't need the travel?
http://www.suspensionconnection.com/...tion/to=r.html
Old Aug 16, 2009 | 01:07 PM
well the firestones on my brother truck are mounted at the base of the leafs not on top of them. And after looking at the lift on my truck the u bolts and the top plate make it nearly impossible to mount the bags on the top of the leaf springs therefore i would have to go from the axle to the frame.
Old Aug 16, 2009 | 01:09 PM
i hadnt thought of that, im sure its something worth looking into
Old Aug 16, 2009 | 09:11 PM
screamn56's Avatar
What about using bags off a semi. they have to be about 16 - 18 inches in height when extanded
Old Aug 16, 2009 | 11:25 PM
Thats what I'm gona look at tomorrow. I measured height and it was 13.75" between axle and frame
Old Aug 21, 2009 | 08:03 AM
nevrnf's Avatar
Check HERE The part #9011 is the longest travel bag avaliable.
Jeff_032500_WI
Sep 5, 2008 10:15 AM
enafzige
25
Apr 26, 2008 10:22 PM
zander79
26
Apr 24, 2007 12:23 PM
CumminsDreamin
Nov 30, 2004 02:37 AM
