Need advice on dash pod installation
So to you guys that have done this:
I mounted the dash pod right in between the two defrost vents, direct in front of the steering wheel. The curves of the pod fit the dash "cover" very nice, by the way. Now, I need to drill the hole for the wiring. I havent seen any clear information on how/where to run the wires after they got through the dash "cover" (this is the one that you remove to mount the pod on). You guys stated that there is just enough room to run the wires between the cover and the plastic dash. But to where? It looks like the best spot would be over to the A-pillar area - just so one would be able to get to the wires after they were pushed through. If so, should the wires run in front of the vent openings? Is there enough room for the wires to be bundled, or do they need to be lying flat?
I have the adjustable pedals, and there is this large aluminum casting that the pedals are mounted to that prevents me from getting to, or even seeing, any wires that would come directly down from where the pod sits. Not sure if all trucks have this casting or not. (on a side note, I finally figured out why I've been feeling uncomfortable driving over the last several months....somewhere along my travels, the button for the pedals must have been hit, so they were back about 2 inches......live and learn!).
__________________
__________________
NoSparkplugs
17
May 17, 2009 10:36 PM
Yukon Dodge
15
Sep 29, 2005 11:53 AM
CTD2001
May 30, 2005 12:40 PM
03CTDCO
Nov 25, 2004 06:04 AM
