My First Carnage
Old Jan 27, 2008 | 02:56 PM
matego's Avatar
madhat's monkey boy...
My First Carnage
I had my first expensive breakage this weekend. The tensioner broke in half. I have been in a diesel shop for 10 years now and never seen a tensioner break like this one. The pulley chunk took out the fan / radiator / shroud / belt.
I was racing my friends D-Max when it let loose. (I did win by the way )
He is pretty cool, he gave me his truck for a couple of days until I get the parts to fix mine.
I am trying to figure out how it broke the way it did. All the pulleys are good and aligned. CTD's really suck when you loose power steering and brakes. I could see it causing a bad accident if a belt broke and cars in front of you.
Old Jan 27, 2008 | 03:15 PM
53 willys's Avatar
cool!!!.....did it break when the boost came on??? or at the end of the race??
Old Jan 27, 2008 | 03:24 PM
matego's Avatar
I didnt really hear it happen I guess with two 7" strait stacks barking behind your head, you dont hear much.
I was going about 85+ when I had him by 4 truck lengths. I went to hit the brakes and I felt like ol' Al Bundy..... No brakes....No brakes!
We had a pack of diesels that night. 2 05 CTDs, 01 CTD, 02 CTD, and 01 D-Max we were all heading to the ski slope to ride tubes down the mountain.
Old Jan 27, 2008 | 05:25 PM
Billm2004's Avatar
Man i bet that was scary when you realized you had no brakes. What did you do to slow her down?
Old Jan 27, 2008 | 05:31 PM
Patriot_Auto's Avatar
I was thinking about that the other day. If we loose or belt we loose our brakes. Sort of a risky situation.
Glad things worked out for you. Parts are fixable, lives aren't.
Old Jan 27, 2008 | 05:37 PM
matego's Avatar
That is one of the nice things about a manual, it slows down pretty quick downshifting with the rpms over 2500.
I cannot believe they dont make these things with an emergency electric booster like the GMC 5500/6500's have. It could have been REALLY bad, no brakes or steering.
Try turning of your engine in neutral next time you are driving and see for yourself how bad it is.
Old Jan 27, 2008 | 06:58 PM
mudder500's Avatar
my buddy called me from the dealer the other day and told me he had 2 come in with the same thing done
Old Jan 27, 2008 | 07:24 PM
Caterpillartim's Avatar
yep mine did yhe same thing, i was lucky got home from a fishing tip and let loose backing my trailer in. what a p.o.s it was like 260 bucks from the dealer and wasnt covered.
Old Jan 27, 2008 | 07:44 PM
matego's Avatar
I hate dealers and their mark ups. Check this out:
3947574 Display part line detail
TENSIONER,BELT $56.31 $56.31 Show part supersession Delete part line
That is the cost of the tensioner from Cummins. How can the dealer mark up the part that much????
Old Jan 27, 2008 | 07:49 PM
dfer10's Avatar
b/c they can, just like the heater block cords
Old Jan 28, 2008 | 10:36 PM
Colo_River_Ram's Avatar
With age comes the cage
Have you installed the over running alternator pulley..it eliminates belt chirp at shut down which causes belt wear and/or shred...it may have led to the pulley breaking as well ..Link to TSB:
http://dodgeram.info/tsb/2006/09-004-06.htm
Old Jan 29, 2008 | 12:10 AM
matego's Avatar
I guess I will have to call and see what they want for one of those pulleys. I dont like the way the tensioner broke and the new one looks identical to the old one. I dont feel real good about it.
Old Jan 29, 2008 | 12:23 PM
The Overrunning alternator pulley should have been a recall but Dodge would rather you and I drive a dangerous truck..
Old Jan 29, 2008 | 03:55 PM
enafzige's Avatar
I thought someone awhile back ran into this, and found one at Napa that was much better quality...may be worth checking out.
FWIW, my tensioner broke as well, but was a result of the Jacob's vacuum pump locking up, and the belt melting till it snapped.
--Eric
Old Jan 29, 2008 | 04:02 PM
skynyrd's Avatar
yeah well i think my motor eat the lobes in the cam of the #4 cylinder! it has a pretty bad knock and the rockers seem like there are some problems.
tcr
Dec 4, 2004 01:51 AM
powerwagon440
Nov 10, 2004 11:59 PM
Gypsyman
18
Oct 2, 2004 11:59 PM
J.R. Adkins
Jun 16, 2003 07:57 PM
Monty
Jun 9, 2003 09:23 PM
