Are my in cylinder temps too high??
Old Jul 13, 2011 | 09:03 PM
89dieselkong's Avatar
So I have been reading that the Smarty Jr. lowers EGT's, which it has on my truck, but at the expense of raising in cylinder temps? I'm running my Jr. on SW1, TM default, and TQ4. This is what I run for towing (10,000lbs) Do I need to worry about my cylinder temps? My engine temps rarely get over 205*(below 200 normally),and so far that has only been towing uphill, in 90+* heat and with a 25mph headwind. EGT's were at 1050-1100 and turbo was at 15psi. I am a little concerned due the overbore on my engine. Input??
Old Jul 14, 2011 | 11:30 AM
Spooler's Avatar
You have no issues. It's all in the timing. Since you run default which is stock, you will be fine.
Old Jul 14, 2011 | 01:57 PM
ok, then are any of the timing settings on the JR going to put me in trouble??
Old Jul 15, 2011 | 12:36 PM
Spooler's Avatar
Not sure about the Jr. I have the S06 model and use timing 3 when pulling. It is the next one up from stock. I have had no issues.
ClassA4x4
Apr 21, 2013 01:15 PM
smog2001
Aug 13, 2007 01:36 PM
cheff
Jan 23, 2006 09:44 AM
Paul Winey
Sep 20, 2004 04:09 PM
RowJ
Jul 20, 2004 10:36 AM
