Motor mounts - 30 PSI 4x4 launches
Old Jun 6, 2008 | 04:22 PM
12valve's Avatar
How well do the stock motor mounts hold up the a 30 psi boosted launch with the 06 truck in my sig.
a guy said, we would rip the motor out of its original place, launching at 30 psi... the billet tranny has still held up to it...
if we do need something better, where should i look to buy something stronger?
Old Jun 6, 2008 | 06:21 PM
jrussell's Avatar
That's pretty high for a boosted launch. I've talked to people who have broken intermediates with 25-30psi launches.
In my experience the 1/4 mile times don't get that much better with a boosted launch over 20psi. If I launch higher than 20psi the tires break loose and 60' times go down but 1/4 mile times go up. Maybe it's different with a single?
Old Jun 6, 2008 | 08:45 PM
ronnyenns's Avatar
i agree with justin. 30 psi boost launch is a little too hard on everything i sopose, tranny, axles, transfer case, motor mounts..etc
Old Jun 6, 2008 | 10:25 PM
chrleb1's Avatar
I used to launch all the time at 25. The motor mounts are the least of your worries.
Old Jun 7, 2008 | 07:10 AM
drillpipe's Avatar
What he said ^^^
Old Jun 8, 2008 | 07:54 PM
12valve's Avatar
thanks!
Whats the next thing to worry about after a full billet tranny?
Old Jun 8, 2008 | 08:03 PM
busa's Avatar
Originally Posted by 12valve
thanks!
Your wallet and wanting to go faster.
Old Jun 8, 2008 | 11:39 PM
Woodchuck61's Avatar
thanks!
Your tranny. (Billet shafts can break too)
Old Jun 9, 2008 | 07:48 AM
paroxysym's Avatar
seriously, a boosted luanch at 30 is redic. i couldnt imagine..
Old Jun 9, 2008 | 08:09 AM
cincydiesel's Avatar
I'm suprised you still have u-joints!!
Old Jun 9, 2008 | 09:01 AM
paroxysym's Avatar
thats a good point. hows the tcase like the boosted launches?
Old Jun 9, 2008 | 09:04 AM
jrussell's Avatar
The U-joints in our trucks are about as strong as they come (not counting the heat/cryo treated ones from aftermarket companies like CTM). I would still be more concerned with the tranny than anything (even if it's full billet).
Old Jun 9, 2008 | 11:10 AM
RunninLean's Avatar
Have you tried leaving on less boost?
I was launching at 18 to 20psi and spinning it was hard to tell I was breaking loose untill I started leaving at 14 to 16 psi and droped a 10th off my ET's.
If I left at 30 psi theres no way I could hook even if every thing stayed together. I dont know how your not blowin the tires off that thing....
Old Jun 9, 2008 | 12:05 PM
12valve's Avatar
It breaks the tires loose, but the road/tire combination on the truck seem to hook well! they break loose for a bit, but hook after that.
i have a question here. does that have to do with the tightness of the torque converter also? cuz the 98 in my sig launching at 20 psi launches just as hard as when the 06 launches at 25 or so. The 06 launches hard, and then it feels like the TC is slipping a little... i guess its normal, but it would feel better if it would keep pulling like it does at the launch.
the 98's torque converter is tighter then the 06´s and it feels like it doesnt slip as much as the 06's, but who knows... the 98 locks up in 1st if i flip the switch
We have tried leaving at less boost with the 06, at 15, at 20, 25 and 30.
60' is 2 seconds at 25-30 psi
Old Jun 9, 2008 | 01:04 PM
RunninLean's Avatar
hmm well I am pulling 1.85 to the 60' leaving at 14 psi if I leave at 18 i will get 1.9 to 2.0.
Try leaving from 10 to 14psi if your breaking loose your loosing time!
