more peformance need help
Old Jan 14, 2007 | 03:32 PM
01smokin's Avatar
my dad has a 2006 3500 cummins 6 speed he has intake banks high ram 5inch duald and the juice w attitude now he wants 2 do somthing else and needs help he sants somthing 2 do with air not fuel he dont think but will concider aneything can u please help me
Old Jan 14, 2007 | 03:40 PM
973604x4's Avatar
He needs a Glacier fuel system...or an airdog...or a FASS
he has reached the limits of the stock lift pump.
air? get a turbo from Industrial Injection. SPS62 is my choice
Old Jan 14, 2007 | 03:45 PM
morkable's Avatar
yes,, air would be a very good next move, afe intake, mbrp exhaust, bigger turbo, better tranny, fass or gdp
Kevin
Old Jan 14, 2007 | 03:46 PM
skynyrd's Avatar
you could do an intake system that will help a little on the high end but you'll lose some of the low end and the turbo will sing to you. intercooler isn't worth it until your going like 600 or 700+. you could change out the turbo to a little bit bigger turbo or a twin setup. but i would suggest adding a pressure box to the fuel system and maybe getting the hot unlock code for the attitude you don't have to send out the 2006 unit you just have to pay 100 bucks and get the code.
Old Jan 14, 2007 | 03:53 PM
01smokin's Avatar
ya thats what i was going 2 do for x-mas but he decied he wanted 2 work on air flow he has high ram intake and exhust
Old Jan 14, 2007 | 04:00 PM
01smokin's Avatar
what do u think about the ats 3 pice manifold
Old Jan 14, 2007 | 04:06 PM
973604x4's Avatar
i have the 2 piece. love it. can't say if it improved mpg or not..but it did change the sound of my truck...and i like it.
Old Jan 14, 2007 | 06:40 PM
dodgezilla04's Avatar
glacier or bd lift pump kit, then an sps62/14.
Old Jan 14, 2007 | 06:43 PM
skynyrd's Avatar
the manifold isn't going help much unless your pushing lots of horsepower. i would go with an intake kit you need to let that engine breath. i'll tell you now that the edge juice has him on the edge of his stock lift pump not being able to handle the fueling needs. the high ram isn't going to do much either until you change out the turbo and your running either twins or a bigger turbo pushing like 50 PSI. and the banks high ram is just about as restricting as the stick intake ram just a smoother surface inside. but i guess the question is how much HP is he wanting to go?
Old Jan 14, 2007 | 08:20 PM
rstone's Avatar
You now need to do like afe air intake and aftermarket fuel system. Then make sure he does some tran upgrade too or he going be sliping tran.
torquedcummins
Feb 1, 2010 11:31 AM
natew05
Dec 27, 2006 11:18 AM
ImLow78
Mar 16, 2005 07:31 PM
j
Dec 21, 2003 10:26 AM
Commatoze
Nov 20, 2003 06:06 PM
