Miss At Idle "please Help"
I Have A Small Miss Sound At Idle And As I Lit Out Of The Clutch It Increases But Once The Clutch Is All The Way Out It Stop And When Im Sitting Still It Does It At Idle But If I Touch The Fuel Pedal And Bring The Rpm To About 1000 It Goes Away Anyone Else Having This Problem Or Have Had This Problem Or Have Any Ideas Of What It Could Be Please Help Thank You
I Change The Fuel Filter Everytime I Change The Oil It Has Only Been Like 3000 Miles Since Oil Change And I've Had This Problem For A Couple Of Months
I had the same problem. After driving and then pulling up to a light it would miss just a bit for a few seconds then go away. I bought some Diesel Conditioner to lube the injectors and all is fine now. Just my .02
Sounds like maybe a fca has gotten a piece of dirt in it and it is hanging up. Are you running a 2 micron bypass filter? The fca is very easy to remove and clean
Buffalo
12-02-2007 08:35 PM
PEAKSTRYDE
10-11-2007 04:20 PM
