Mag high tech VS PML
Old Jul 20, 2007 | 10:11 AM
  #31
jrussell's Avatar
Originally Posted by Nate-03 D
Forgive my ignornace here but what exactly is the difference between a 10.5 - 11.5? Just the size of the cover in inches?
How would I go about finding my axle size? I have a 03 SO Auto 48re, 2500.
I believe the 10.5" and 11.5" measurements refer to the ring gear diameter.
I assume the 11.5" axle has a slightly larger diff housing? If so, you could park next to a newer CTD that definitely has the 11.5 and compare the two.
Old Jul 20, 2007 | 11:00 AM
  #32
2003Ram's Avatar
10.5 and 11.5 are ring gears sizes. The 10.5 is the same size as a Dana 70, the 11.5 is equal to the Dana 80 in size. (don't confuse that with being able to swap covers)
The '03 2500 SOs are a bit of an odd duck (early '04s as well). Some could have an 11.5, but it is more than likely they have the 10.5.
All HOs have the 11.5. All 3500's have the 11.5.
My 2003 2500 SO has: 48re, 10.5 rear with 4:10s + anti spin, cat, and passenger side keyed door lock.
Old Jul 20, 2007 | 11:30 AM
  #33
HOBrian's Avatar
Nate, Ram 2003 has a SO and a 48re so I have no idea. I am just going to do this for a while
Old Jul 20, 2007 | 12:18 PM
  #34
Nate-03 D's Avatar
No need to bang your head any more.
All pre 03/03 model trucks that came with the auto were equiped with the 47re. I don't know the exact date that Dodge started using the 48re's but I know it was in the 3rd month of 2003.
I just went down to my truck(to rehang my alarm sensor, doubled sided tape on plastic is no good) and I looked in the glovebox on the spec sheet and it stated that I do have the 10.5 rear axle with 3.73 gears.
Ok, so now that's all taken care of. Whats the real difference between the two? Better towing capabilities, acceleration?
Old Jul 20, 2007 | 12:25 PM
  #35
jrussell's Avatar
Strength. The bigger the ring gear, the stronger it is (generally speaking).
Old Jul 20, 2007 | 10:31 PM
  #36
gsdog1's Avatar
The MH front differential cover clearance issues were taken care of a while ago at least for stock front end suspensions, correct?
Any issues with some of the improved trac bars that anyone is aware of?
Thanks!
BIGDAN65
13
Feb 16, 2009 08:24 AM
dogcamo
Mar 31, 2008 07:37 PM
1stTimeAround
Sep 7, 2006 07:51 AM
eswartz
Jun 14, 2006 07:15 AM
TexasCTD
26
Mar 14, 2005 08:40 AM
