Mag-Hytec or PML trans pan
Old Mar 30, 2008 | 08:09 PM
dogcamo's Avatar
Which one would you all purchase? What are the pros and cons?
Old Mar 30, 2008 | 11:45 PM
trik396's Avatar
I've got the PML. Less expensive than Mag. Still very nice quality. No problems in around 20k miles.
Old Mar 30, 2008 | 11:58 PM
Grodyman's Avatar
I have a problem spending $180 for a diff cover, especially when I found out that you can get the oem Ford alum diff cover that comes standard on 08+ superduties for about $67.
Gman
Old Mar 31, 2008 | 12:13 AM
Mopeman's Avatar
I will probaly got for the PML covers when I do this mod just because of the price. You could save at least $130. I will have to look into the pherd cover, just the thought of putting a pherd part on my truck makes me . I didn't know that they had AAM axles in them.
Old Mar 31, 2008 | 01:29 AM
mopardamo's Avatar
Hello,
I just checked some quality differences and was not impressed. The gasket seal is a concern. The Mag-Hytec has an O-ring and take a look at the fin difference. The black color adds $40.00 to the PML cover making the price about $30.00 dollars apart retail. Do you have different info? My check was pretty quick.
Damon
Old Mar 31, 2008 | 02:19 AM
trik396's Avatar
He was asking about a trans pan, not rear end cover.
My PML trans pan isn't black, it's aluminum. If it were powdercoated, I'd think that would hold in heat and wouldn't be good.
Old Mar 31, 2008 | 07:19 AM
eddiebob's Avatar
I have the PML transmission pan and rear differential pan on my 2005. They have been on the truck for a little over two years and 25,000 miles. I have had zero problems with either of the pans. I run the PML instead of the Mag because of the price and the sand cast material without the powder coat was what I wanted. Ed B
Old Mar 31, 2008 | 12:42 PM
ptgarcia's Avatar
I have the Mag on my '06. Bought that one because it's already drilled and tapped for a temp sender. Paid $250 shipped from Geno's.
Old Mar 31, 2008 | 06:56 PM
rjm022's Avatar
i have both the pml diff covers-great product. i had the pml tranny pan- which holds two additional quarts of fluid- i noticed no drop in tranny temps. switched to the mag hytec tranny pan and i got lower temps of roughly 15-20 degrees.
Old Mar 31, 2008 | 07:37 PM
lniemeyer2's Avatar
I have had the PML pan since 03 and no problems, love it. I noticed about a 50 degree temp drop from the stock pan although I did move my temp probe from the port in the side of the tranny to the pan when I installed it.
I thought people were saying that they saw no drop with the Mag pans supposedly because of the powder coating. Anyway RJM seen a difference with the Mag so I don't know.
RJ285
May 7, 2011 09:52 PM
BIGDAN65
13
Feb 16, 2009 08:24 AM
EverydayDiesel
Nov 11, 2007 09:33 AM
eswartz
Jun 14, 2006 07:15 AM
TexasCTD
26
Mar 14, 2005 08:40 AM
