Fuel pump Fitting
Old Mar 30, 2008 | 06:13 PM
Ducman82's Avatar
Fuel pump Fitting
does anyone know what size thread is on the banjo bolt that goes in to the Cp3 on an 06? im thinking of making a 2 micron filter setup. and does anyone know if JIC is the same as a AN fitting?
Old Mar 31, 2008 | 10:15 PM
C Schomer's Avatar
I think the banjo bolts are 12 x 1.5mm. Craig
Old Apr 1, 2008 | 05:34 AM
mini14's Avatar
jic and an are different, but i believe an is 45 degrees on the taper and jics are either 37 or 45.....id go with the jic cauz they should accept 45 and 37 degree tapers with noprob. jics are mainly used in hydro apps and will withstand higher psi.....i also think an can be ordered in either 37 or 45 degree, just make sure all your connections have the same taper.sorry for any confusion someone else please correct me if im wrong.
Dean Snow
Apr 18, 2010 06:19 PM
barngal6
Jul 5, 2009 11:07 PM
BearKiller
Jul 15, 2007 10:02 PM
LanceD
May 1, 2007 04:38 PM
BRD
May 20, 2005 04:40 PM
