Low Boost!
Low Boost!
Hey guys this is an off shoot of my previous thread but I am getting very low boost numbers...just cruising around I have 0 boost and at WOT the highest i have ever seen is 15 and that is with the BDDL at Extreme setting. Without the BDDl the highest i get is about 15 as well. I have seen some guys saying they are getting 30 really easy with stock. What do you guys think??
Grant
Grant
Well one thing what kind of truck do you got fill in your sig. But as far as that goes how does the truck run does it have all the power? If the truck runs good and has plenty of power You might want to check your gauge.
sorry bout that I will fix it...no it doesnt feel like it has all the power...it will barely puff any smoke under full throttle with both of my boxes on...it is definitely powerful but I thought that with the two stacked (power pup and quadzilla) i should have LOTS of power and should probably be able to bust the tires loose with full throttle.
By the way for now....the truck is a 2003 SO (250 hp) 3500 srw quad cab, with 4.10's, full DTT tranny 89% TC, Power pup, quadzilla box, Nitto 295's, 4" MBRP exhaust, AFE Stage2 Intake, boost, pyro and tranny atutometer gauges
Moobesor
Feb 23, 2008 09:57 AM
