Looking for the next upgrades
Old Jul 29, 2007 | 12:26 PM
dodgecowboy04.5's Avatar
I am leaving for Iraq in the next couple of weeks and when i return i will have a little bit of money to spend on my truck. Just want to get some recomendations on what to buy for my truck when i return. I plan on spending around $5000. A list of stuff i already have is in my signature. Any comments would be greatly appreciated.
Old Jul 29, 2007 | 12:29 PM
rustyshakelford's Avatar
south bend clutch, gdp fuel system, hot juice upgrade, studs and a turbo
brett
Old Jul 29, 2007 | 01:36 PM
rufushusky's Avatar
I would get a beefier clutch, fuel systems, turbo and depending on the turbo, some head studs but if the peak boost is under 50 psi you shouldn't NEED studs but they would not be a bad idea.
Old Aug 1, 2007 | 07:46 AM
What tubro should i get. I don't want twins but i want something that puts out decent pressure. Also what about injectors, any recomendations or should i stay away
Old Aug 1, 2007 | 07:52 AM
rufushusky's Avatar
Hmmm...something like a 64mm turbo....like phat shaft 64.....
Old Aug 1, 2007 | 08:26 AM
farmboykjb5.9's Avatar
Get a hold of Don at F1 if you want injectors cause their one of the best u can get.I'd go with the flux1s if u dont want to have to get ur cp3 modded and if u do go with the flux2s if u want to do the cp3 mod.I'd go with a II phat shaft 62 or 64 turbo.
technolackey
15
Oct 17, 2009 11:06 PM
fbgdiesel
May 1, 2007 09:40 AM
Vanb
18
Mar 9, 2006 03:54 PM
Mcmopar
Mar 9, 2004 10:45 AM
