Leveling Kit not that Great
Old Apr 9, 2008 | 10:25 PM
dslpwr81's Avatar
Just had a leveling kit installed today. I know its probably not the best
(I know) kit out there. Should have went with KORE. It is a Tuff Country. Don't laugh. Anyway, is there anyone else out there unhappy with theirs? The ride has changed... its a little stiffer. I had the shocks installed too. When I hit bumps in the road, I hear a thud sound. This kit seems really cheap. Is there something wrong here??? I guess you get what you pay for. Any suggestions? How hard are they on front ends, etc....
Old Apr 9, 2008 | 10:36 PM
nriver's Avatar
no idea on the ride.
If you have a thud, your lower shock mounts bolts may not be tight enough. Does it feel like it is coming through the floor?
Old Apr 9, 2008 | 10:38 PM
dslpwr81's Avatar
It doesn't really feel like its comming through the floor, but you can feel it a little in the floor board. I have checked everything and all is tight and good. I can't figure it out. They guys who installed it at the tire shop said they have installed a ton of them, but yet it took them ALL day to get the coils out. WOW. Seems a little funny.
Old Apr 9, 2008 | 10:52 PM
nriver's Avatar
I had this problem. I have had the front suspension out many times with the various changes I have made.
They may appear tight, but the shock tabs did not compress against the sides of the shock. You may need to really torque it down or put a spacer on the bolt to close the gap.
I would check it again, you may even be able to shake the shock a bit with your hand or a strap.
My guess on what it might be. good luck.
Old Apr 9, 2008 | 11:06 PM
dslpwr81's Avatar
Thanks. Will check it out in the morning. I have to figure it out. Its very annoying and it doesnt sound good. It will drive me nuts on a dirt road.
Old Apr 9, 2008 | 11:12 PM
Big Blue24's Avatar
Make sure the shocks are long enough. After my leveling kit, I had a little thud, but only when the front end decompressed all the way and I finally figured out that it was the shock bottoming out by opening too far.
Old Apr 9, 2008 | 11:16 PM
dslpwr81's Avatar
OK. Tuff Country supposedly sent the longer shocks for the kit. How do I know for sure now that its installed?
aaronmt
0
Jul 5, 2012 12:06 AM
sgtdiesel
25
Jun 26, 2012 02:37 PM
Riverbound
14
Nov 1, 2009 01:42 PM
lgp9999
Nov 16, 2007 08:57 AM
