leveling kit ?
Old Nov 1, 2005 | 08:26 PM
ftltmp's Avatar
Question leveling kit ?
Has anyone used a leveling kit for the front of your truck? I think it is supposed too raise the front end 2" . I have a chance too buy one off a guy I know , all four shocks, spacers and all for 175.00. Any thoughts or comments would be apppreciated. Thanks
Old Nov 1, 2005 | 08:52 PM
Nate-03 D's Avatar
My father had one in his truck when he had 35's on it. Worked great and made the font the same height as the rear. He removed it and put on a 6" lift w/ 37's.
I'm putting one on my truck tommorow along w/ 4 new shocks. There are two ways of putting it on. One way is to use a spring compressor(the easiest way), if you do that make sure it is heavy duty not a wimpy one. Or the second option is to drop the front axel, disconnect the brake lines and all that and then put the kit on.
$175 dosen't sound to bad at all. But then again mine was free so I realy can't say how much there worth.
Old Nov 1, 2005 | 09:12 PM
CASMOKIN's Avatar
I installed a 2" Daystar Kit with new Bilsteins all around. I moved up to 35's with that set up. Every once in a while I wil get minor rub. Im happy with it Pics in my gallery
Old Nov 1, 2005 | 11:00 PM
jwtuc's Avatar
[IMG] [/IMG] I used the Skyjacker 2.5 coils . They are very reasonable ( I paid $300 installed ) . I have the Warn heavy duty bumper (400#) and they leveled my truck great . They may be a little stiff if you do not have a heavy bumper . I also installed bilstein 5100s .
Old Nov 2, 2005 | 03:51 PM
Booboo's Avatar
What does the kit contain. Do you have to relocate brake lines and stuf like that?
Old Nov 2, 2005 | 03:59 PM
bama's Avatar
no need to take loose brake lines....take loose track bar,sway bar,upper and lower shock bolts,,,,drop front end down,take 3 bolts for towers out,,,pull out shocks,coils.put in spacers,back in shocks,towers,coils.hook back up sway bar and track arm.....done.........plenty of slack in brake lines........bama
Old Nov 2, 2005 | 04:31 PM
Booboo's Avatar
Cool doesn't sound to hard thanks.
Old Nov 2, 2005 | 05:06 PM
jwtuc's Avatar
A coil compresser is a big help . The new taller coil on the passenger side is difficult to get in , the driver side slips right in . I watched them do the installation .
Old Nov 2, 2005 | 06:32 PM
PsRumors's Avatar
Where was this? I come through Nashville quite often and would love to make a pit stop. $300 installed does not sound bad.
Old Nov 2, 2005 | 07:11 PM
bama's Avatar
he is correct about the passenger side being a little tight...take the track arm loose and itll give you the room you need........bama
Old Nov 3, 2005 | 10:34 AM
Mike67RS's Avatar
Do a search and read up on Death Wobble first.
Old Nov 3, 2005 | 12:53 PM
cquestad's Avatar
Do a search for a proper alignment shop first and save yourself the waste of time of worrying about DW.
Old Nov 3, 2005 | 04:45 PM
jwtuc's Avatar
PsRumors , sending you a PM with that info .
Old Nov 3, 2005 | 07:52 PM
ftltmp's Avatar
Does adding the leveling kit create the death wobble?
Old Nov 3, 2005 | 09:31 PM
StealthRam's Avatar
I just sent my skyjacker 2.5's to my powdercoat guy, going black. Im not much of a bright red guy Anyway, i can get a deal on these springs ($185.00), ill put the pics up when i have them put in.
