lets sum it up on '03-'04 smarty settings
Old Jul 24, 2010 | 12:27 PM
MulesDiesel's Avatar
before I picked up this tuner I was searching on here and found a thread where someone stated the smarty was the best for the '03-'04 pickups. better than bullydog, edge, ect. I've been running on level 3 and like it but want more.
My truck is stock except srt8 pipe and gauges (boost, egt) and the smarty now. Its an '03 3500 srw with the nv5600. would level 5 be ok on the stock '04.5 style lift pump? how about the clutch?
any other advice on tuning the '03?
My plan for upgrades are;
Lift pump
Clutch
50hp sticks
maybe bigger turbo if I feel like going that far.
thanks
Old Jul 24, 2010 | 03:22 PM
21 views and no one has anything to say about an '03 with the smarty?
Im wondering if I can safely run sw5 on my pickup w/out a fuel pressure gauge
Old Jul 24, 2010 | 04:03 PM
Raspy's Avatar
I've been running mine on 5 for years.
Smarty is a duration box not a pressure box. Or did you mean a lift pump pressure gauge?
Old Jul 24, 2010 | 04:51 PM
SuperiorRam's Avatar
I had a edge w attitude on five and smarty on eight for two years
stock sticks lift pump and a 06 turbo made 480/1038
my advise is watch the pyro
I'd rearrange yer list to
lift pump
clutch sb 3600
turbo
then sticks
now run smarty and edge ez with twins
Old Jul 24, 2010 | 05:28 PM
Thanks for the replies. I didn't realise the smarty didn't add pressure. I would need and edge or similar for that then? What about the tnt software?
Old Jul 24, 2010 | 05:51 PM
1985cucv's Avatar
adding pressure is bad for the stock injectors it can cause them to fail keep the rail pressure stock on the smarty and then turn it up for what your doing right now i believe the stock clutch will handle level 5 but when you get over that you might need an input shaft on the nv5600 i think somewhere around 450hp the stocker is good for. other than that my truck liked sw7 torque 2 or 3 timing on 3 for some reason (if it doesnt pop) if not timing 2 and rp 1 or stock and wastegate off. for some reason my truck on timing 3 was way faster and didnt pop until it got warmer out? now i run the tnt on sw5 or 7 with timing on 3 and it feels good. every truck is different!
Old Jul 24, 2010 | 05:52 PM
I have always ran TNT now run TNT/R
I'd stay away from edge pressure box like Dr performance is my next step others will undoubtably tell you mp-8 or tst but constantly running pressure boxes will kill injectors period
Old Jul 24, 2010 | 05:59 PM
I keep reading about how bad the pressure boxed can be so I will be staying away from them for now anyway. I want power but will not sacrifice reliability for it.
and to raspy, yes I ment Lift pump pressure guage.
Old Jul 24, 2010 | 06:00 PM
My truck has been over 450 for years and now way north of that on the stock input
odd number software will pop on my rig i always run even
tq management 1 for twins, 4 for small single, 4 will smoke I stay low here
timing 2 on my stock stick worked best now with the 200+ sticks I run 3
Rail pressure get a gauge run 1 for better injector life trust me...
Old Jul 25, 2010 | 12:39 AM
Raspy's Avatar
Mule,
Go ahead and get the lift pump now, before you have to get towed. I recommend the Glacier Walbro setup. My Walbro has been perfect for over 130,000 miles and I can slip in a cheap replacement in about 15 minutes if needed with minimal tools. Not a big fan of LP pressure gauges, but I do have one screwed onto the top of the fuel filter. When the LP fails it just fails and stops the truck.
I'd like to get a set of 50 HP injectors too, but my tranny already slips whenever I get on it so what's the point? After the tranny, the injectors and a 351 turbo are in the works.
Old Jul 25, 2010 | 12:56 AM
My ole 351 got plenty hot with the stock sticks btw
Old Jul 25, 2010 | 10:52 AM
Thanks guys
Old Jul 25, 2010 | 12:58 PM
JTaylor's Avatar
x2, especially when you darn near run into the 12's with the Stock Exhaust and Intake.
IMO, If you are after reliability. I would invest in a Larger Turbo before installing aftermarket nozzles. Also, invest in a 2 micron fuel system to make sure that you have properly filtrated fuel.
Old Jul 26, 2010 | 03:25 PM
moorepower's Avatar
Beta 4.4 level 3.
Old Jul 26, 2010 | 04:45 PM
Originally Posted by moorepower
Beta 4.4 level 3.
Thats what your running? how does it compare to lvl 5 on the standard software?
keat
Feb 6, 2008 07:42 AM
PossumDdieselTs
Feb 4, 2008 12:31 PM
D.Wiggs
31
Aug 30, 2007 02:48 PM
tristan21
Mar 17, 2006 11:29 PM
Turbodude
Dec 15, 2005 12:42 PM
