Leaking Coolant
Old Dec 7, 2008 | 03:21 PM
Hintz's Avatar
Leaking Coolant
Well had a little puddle on the driveway and its coolant and its leaking from what looks like a heater hose, maybe?
It looks like its leaking from the hose and this is right next to the 5 cyclinder. Any ideas thoughs? Could this be why Im getting the P01458 High Pressure CR?
Old Dec 9, 2008 | 03:30 PM
Hintz's Avatar
TTT, anybody Ive been told by one fella, is no big deal just get some better clamps, any thought?
Old Dec 9, 2008 | 09:08 PM
modjunkie's Avatar
I have a leak also but mine is the short peice of hose that connects the two steel tubes behind the turbo. I would take that pressure clamp off and put a better clamp on. If that doesn't fix it then you might need a new hose. If pressure was a problem it should be pushing out of the cap and then could be a whole list of things causing that leaking head gasket, bad thermostat, bad water pump. Put a clamp on I'll bet that fixes your problem.
06 mega cab, edge att, magnaflow 5", leveling kit, 295/70-17 toyo mts.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
DTE
Oct 8, 2004 07:02 AM
