K&N or not to K&N...
Old Jul 8, 2007 | 03:56 PM
nelrod's Avatar
Amsoil Nano with cool blue hose.
Old Jul 8, 2007 | 04:06 PM
danc46's Avatar
I ran a K&Nair filter in my 2000 Dodge Cummins for 173,000 miles. I cleaned it twice a year. I never had a problem with the turbo nor wear on the engine from "dirt being sucked in".
When I sold the 2000, it did not burn oil and still ran strong. As a matter of fact, I believe it was running stronger than when I got the truck new.
I have a K&N in the stock filter housing on my 2006 with 10,500 miles on it.
I have enough faith in the K&N I'll keep it on the truck.
Old Jul 8, 2007 | 06:11 PM
vzdude's Avatar
DTR's 'Go to Guy'
^ Me too! I have the K&N drop in. I just had mine out today to clean it - and to check because of this thread! Not one spec of dust in the tube, or oil in the tube or turbo. Just so happens though, when I was at Autozone to get the cleaner kit for the K&N they had a cone air cleaner ( like comes with most of the amk. intakes ) on clearance. 70% off the already clearance price of 24.99! Do that math! Thats only $7.50 ! I bough it and a 3" PVC pipe union and put it right in the end of my factory air intake hose. Even drilled a hole in the PVC for the air temp sensor. Whole thing cost $8.49 plus tax! The turbo screams now! It is still an oiled filter just like the K&N so I will check the tube every day for a week ( I drive over 100 miles per day ) and go from there! I'm gonna go get the specs off of the package. Hopefully someone can post the specs off of a factory filter if they have it.
Old Jul 9, 2007 | 08:01 AM
JohnInNH's Avatar
I like the Nano filter.. good flow. No dust or oil to worry about. I run K&N on my bikes and my Miata.. all 3 let in slight amounts of dirt/dust. They run cleaner dirty. If that makes any sense.
With the lower miles on the bikes and less $ invested I don't mind. But NOT on my truck!
Old Jul 9, 2007 | 08:45 AM
wade234's Avatar
Only K&N?
Is this limited to K&N or all oiled filters? I am using an oiled AFE stock filter replacement (drop-in). After reading the this post I am a little worried. I know they make a dry filter but I just spent the money on this one. Should I run it till it needs to be cleaned then think about a dry? Sounds like most people have problems after they clean and oil the filters? Thanks.
Old Jul 9, 2007 | 09:15 PM
HOHN's Avatar
The answer is simple: NOT.
IMO, the answer to any question about whether to use an oiled gauze filter is always NO!!
Especially since we have such great, high flowing dry filters out there now-- there's no need for oiled gauze.
Look at the Donaldson Endurance and AEM Dryflow...
JH
Old Jul 9, 2007 | 11:05 PM
bigcat83's Avatar
T he afe filters are a good brand filter but you have to mantain them.i like my aem its alot easier to keep clean,and flows well.
Old Jul 9, 2007 | 11:19 PM
jwb600's Avatar
Originally Posted by PourinDiesel
If you want the best oiled intake out there do it right the first time and get an AFE Stage 2.
ya what he said
Old Jul 10, 2007 | 08:52 PM
el jefe's Avatar
I had a K&N for about two and a half years and around 60k miles. I didn't have any trouble with it. I did switch to an amsoil replacement filter about two months ago for kicks and grins, but when I installed it, I wiped the intake tube with a paper towel and there was no residue. Hope this helps.
Old Jul 10, 2007 | 10:02 PM
ohyeahfriday's Avatar
I want to be honest here, like el jefe above, as I said, I am running a K&N full intake with the conical filter. Last I checked, there was no dirt/oily rseidue inside my intake tube. I juse prefer the peace of mind of getting the Amsoil Nano.
Old Jul 10, 2007 | 10:07 PM
annabelle's Avatar
Not.............
Old Jul 10, 2007 | 10:11 PM
Jays98dodge's Avatar
Just a note to all that think K&N is a good filter, I wouldnt run one on my lawn mower. They lost the patent years ago and are living off the name they set a long time ago. There no good anymore, sorry K&N thats the way I would have done it also. Build my name up and then let it go to hell and ride the wave. K&N is living off there reputation.. Just my .02....
Old Aug 14, 2007 | 08:08 AM
Sprinter17's Avatar
Muted User
I agree, I was using the filter 30yrs. ago on my street bikes, and they haven't changed since then. The only reason their were a hit back then was because they were the only aftermarket filter available anywhere, and their definitely not high tech., just gauze.
Old Aug 21, 2007 | 01:18 AM
kpatrick's Avatar
Fomer desert racer here. I tried K&N back in the early eighties. Filter was junk and sucked more dirt in the motor than if I just ran panty hose over my intake boot. It's funny to read about this here. There's a jeep forum that members complain about K&N's sucking dirt too.
Old Aug 21, 2007 | 09:03 AM
quadman20's Avatar
I just installed the new AFE prodry drop in filter. Flow is way better then stock. I went with AFE for filtration % is one of the highest far more then airaid or K&N.
I've also ran k&n in other things as quads and have since went back to something else had poor filtration lots of dirt.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
hotdram
Nov 17, 2008 08:50 AM
Ridiculous
May 17, 2007 07:28 PM
Mark Hodowanec
Feb 26, 2006 08:35 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
