Just upgraded MMM to XZT+
Old Nov 29, 2007 | 08:16 PM
susee80's Avatar
Stroop, I want a ride! I hope they make this for the 6.7 soon! don't want to hijack but can some one explain torque management to me, I am a little slow
Old Nov 29, 2007 | 08:32 PM
greg_bingham's Avatar
Originally Posted by thefrog
Guages are a must with any fueling box. I highly recommend the commander with all info at a push of a button and the min/max feature makes it a must have.
I have seen as high as 1450 on my pyro pre turbo and boost as high as 40 PSI but what concerns me is my fuel pressure will drop to 2-3 PSI under hard acceleration, I think my LP is weak from the factory.
Truck runs much smoother and has better throttle response but the timing rattle is a little annoying so I usually leave it on 25hp setting for normal driving and only use the 45-65 hp settings for towing.
I better intake or a free flowing exhaust will help in the EGT area but keep an eye on the fuel numbers.
-Frog
frog,
what exactly is the concern about your fuel press drop?
bad for the system or something?
i thought the issue was a drop in rail/acc pressure....
i don't think i'll be running the XZT software towing, should i be concerned about the occasional WOT i do passing some dump truck or stupid ***** doing her makeup on my way to work?
bluebull
Nov 15, 2007 10:19 AM
darrenb
50
May 30, 2007 05:53 PM
Bad Ramer Jamer
Dec 8, 2005 07:17 AM
Journier
Nov 22, 2004 02:56 PM
