Just got approved for injectors
Old May 24, 2007 | 10:44 PM
Sevir's Avatar
My bank (AKA the Wife) pre-approved me for a set of injectors. I am looking at the DPP 90hp injectors (mainly because I am moving to Seattle and they are right down the road and i have read good things about em). My question is what else do I need to do to my engine to handle these. I know i need my tranny is in need of a upgraded and thats in due time. I am thinking Head studs is a must and will eventually get a turbo.
Old May 24, 2007 | 10:51 PM
morkable's Avatar
DDP is a good company, but by the looks of it you do towing, I would recommend going with 50 hp sticks. They will actually increase your fuel mileage, and you will still need to upgrade your fuel system. 90's are good if you are going to race, but for towing stay with the 50's,, and trust me they still make big power
Kevin
Old May 24, 2007 | 10:54 PM
Sevir's Avatar
I was looking at the 50's also. I dont do all that racing stuff. Mainly for fuel milage and a little extra power. I will take that into consideration.
Old May 24, 2007 | 11:19 PM
morkable's Avatar
Then definately go with the 50's. That would be the ticket for you!!
Kevin
Old May 25, 2007 | 09:49 AM
dodgezilla04's Avatar
When you get them, i would like to talk to you about your differences, since i am looking too.
chris
Old May 25, 2007 | 06:16 PM
blownsmoke2's Avatar
My question is what else do I need to do to my engine to handle these. I know i need my tranny is in need of a upgraded and thats in due time. I am thinking Head studs is a must and will eventually get a turbo.[/QUOTE]
With a stock tranny and turbo I can't believe your even considering injectors. The tranny will not hold and the turbo will never cool it. Also with 90 hp inj it drains the rail too fast. I was having that problem with 80's. Get the hot upgrade from Edge for $100 and put the rest toward a convertor and valve body at least. The hot upgrade will give you more fuel than you can cool now and the tranny upgrades will feel like another 50 hp.
Gotsmoke6 has a 62-14 turbo and a smarty anything over 60 hp and the convertor slips. 170 hp and it shutters and shakes
Old May 25, 2007 | 07:11 PM
Morse's Avatar
Don't worry about the studs.. You are far from needing them.. As the others have stated, take care of your trans. A converter/shift kit is good enough to hold your truck to some quick quarter times especially being that it's 2wd. Look at my signature.. My 06 2500 is doing low 12's at 111 mph on a very simple setup. Here's my suggestion in order.. Torque converter/shift kit, 62-14 turbo, DDP 90hp injectors.. You'll be running very quick at this point.. Then you can focus on extras such as the lift pump.. This combo pulls heavy trailers easily, and does very well on mileage..
Old May 25, 2007 | 07:16 PM
03qclb5spd's Avatar
Trans first.....you'll thank yourself later!
Old May 26, 2007 | 11:56 AM
morkable's Avatar
You definately dont need studs, unless you plan on hitting over 50lbs of boost continuously. Personally, I think that 90hp sticks are too big for a stock turbo and fuel system. I personally think that 90's are more of a high end street / race size. I am getting lots and lots of fuel from my 50's, and they helped my fuel mileage, and work great for towing. I will probably upgrade my sticks later this year, just cause I dont tow any more with this truck.
I personally thing the first order is allways the tranny, and then the fuel system (fass etc) then air/exhaust. Then get the electronics going. When you start to get too crazy with the electronics, then cp3.
Kevin
Old May 26, 2007 | 12:39 PM
wimpy76's Avatar
With my current setup will 50's drain my rail? Looking for a little better mileage while towing.
Bill
pwrtripls1
Dec 23, 2005 11:10 PM
pwrtripls1
Dec 22, 2005 12:28 PM
sshelly
21
Aug 22, 2003 08:58 AM
