juice stacked w/ XZT minus timing: Tonight!
Old Jul 14, 2006 | 03:20 PM
Big Horn's Avatar
I just got an XZT without the timing to stack with my juice and I am excited to put it on tonight. Does anyone else have this stack yet?, or a similar stack. I am hoping to get some good smoke. I don't know what to expect for numbers but I don't thing I will be turning the juice up all the way very often..... maybe.... well i am going to try not to. what do you think, will i get more smoke?
Old Jul 14, 2006 | 05:24 PM
cquestad's Avatar
a big YES. A little pressure added to the Juice livens things up a bit.
Old Jul 14, 2006 | 05:43 PM
staarma's Avatar
If you aren't careful you just may get some smoke from your tranny too.
Let us know how the stack goes. Sounds interesting.
Old Jul 14, 2006 | 06:43 PM
swansong04's Avatar
geesh now you guys got me all excited my xzt is sitting down at the post office .. i am gonna go pick it up tomorrow and try to stack it with my J/A also !!! ooooh i can't wait .. my tranny is still strong(touch wood) but i know i will have to take it easy now .... dtt is gonna see it in the fall anyway .... i hope there is more smoke too ... heheheheh I'll post my findings tomorrow and tell you all how it went ... and thanks again to quad for hooking me up !!!
Gary
Old Jul 14, 2006 | 08:52 PM
Boz007's Avatar
So without the timing, is the XZT just a pressure box or a pressure/duration box?
Old Jul 15, 2006 | 12:43 AM
Big Horn's Avatar
without the timing it is pressure only, from what I was told. The guy at my local diesel shop told my as long as I am not to crazy with it the stock tranny should be fine for quite a while. I guess if it is to much I might take it off untill I get a TC and valve body. I didn't get it put on tonight so I will be doing it tomarrow. I am going to the Bully Dog days to watch the Dyno comp in the morning and I will probably put it on while I am there, but I don't think I will be making any runs on the dyno because I didn't sign up. It should be fun to watch though and maybe there will be someone there that has a stack like that so I can get a ball park figure of what i am at.
Old Jul 15, 2006 | 07:52 AM
trik396's Avatar
It's pressure and boost fooling only. Stacks pretty well with my Diablo which is timing and duration...
Old Jul 15, 2006 | 06:03 PM
Big Horn's Avatar
well it is on. It does smoke more and has a little more on the bottom end. The temps seem to rise alot faster which i expected. I think i hooked it up wrong the first time because i got a CEL, but i switched it around at the map sensor and it runs great now. i hooked the xzt to the map then the juice to the xzt, and then then factory wires to the juice. does this sound right? the only other thing the light might have been is if i didn't get the trottle position sensor tap on to the wire good, but i think i did.
Old Aug 8, 2006 | 07:14 PM
swansong04's Avatar
Thumbs up
well , i just got back from a little test run .. my first impressions are very positive !! it REALLY pulls hard in the bottom end and ooooh sooo smooth !! it does smoke a little more and the egt does get up there faster , but still tolerable ..actually on 5/5 on the juice and the xzt on there the truck is almost scary now .. you get up to 80 miles an hour just like that !!
thanks again for quad for the awesome support and the free re-flash !! and wow what a stack .. can't wait to dyno it !! no CEL'S !! in the higher rpm's the engine gets a little rattly now though ..
anyway i took it back out till i get my tranny beefed up .. for now it will sit on the shelf !! but what an awesome stack !!!
Gary
Old Aug 8, 2006 | 10:05 PM
qzilla's Avatar
Glad it works well. Let us know how it goes when you get the tranny fixed.
Also in the pretty near future look for some info on our new stacking products!
Old Aug 9, 2006 | 01:53 AM
streetsmoker's Avatar
Hey Quad, do you have anything that would stack well with my Edge? Coinsidering the Race Box (has the same advertized #'s as my BDPP). I know it does all 3 parameters. I don't belive all the BS about overlapping them, and was just wondering. I'm getting pretty tired of the programmer and the few, but very irritating flaws it has and Bully Dogs almost abandonment of support for their customers still running the original Power Pups. They know these prob exist and still have no updates to fix it. Other than "all these are fixable with our Tripple Dog".
Old Oct 3, 2006 | 03:36 PM
AkitaSumo's Avatar
qzilla
Any info on these great newproducts of yours? I am looking at stacking one of your productswith my Edge Juice with Attitude.
Old Oct 3, 2006 | 05:05 PM
marc03's Avatar
QZilla,
Where can I puchase the XZT without timming? Do I have to buy one a send it in for a flash? I wish I would have never sold my XZT when I got the juice.
Old Oct 3, 2006 | 05:29 PM
morkable's Avatar
I am wondering if I could stack that xzt in with my hot juice and a diablo predator? And if so what would be good settings
Kevin
Old Oct 7, 2006 | 04:25 PM
omaharam's Avatar
Bighorn
Have you had any issues since your xzt install? My truck wants to die when driving normal on level5.
