Irritated
Irritated
Okay I have changed vp44 and lift pump on my 2002 ram 2500 5 speed because it was having dead pedal issues from time to time, got only about 6 months of it running like it suppose to and now started doing the same thing but seems to be more often then before. While I am driving I can switch key of and then back on it will take of like it shot out of a gun! Irritated with it is understatement.
My understanding of the vp44 is it either works or it doesn't so I would assume that would not be the problem Member KATOOM wrote::There is many years of accumulated misguiding info out there but if you search long enough you'll find that the best fuel pressure for the VP is no less than 14-16 at WOT. Whatever it takes to achieve this psi from the idle to WOT pressure drop is what the idle psi needs to be. Most aftermarket fuel pumps equipped with aftermarket fuel lines will result in around a 3-5 psi drop from idle to WOT. Stock lines and less than adequate fuel pumps will have a larger pressure drop. Pressure over 20(ish) isnt a problem but isnt necessary unless you cant keep the WOT pressures at 14-16.
That said it sounds to me like an intermittent electrical problem
Go to Blue Chip like suggested in here: Code P0216 - Dodge Diesel - Diesel Truck Resource Forums
ok I went to blue chip done some of the check list no where near all of it, I ordered the pressure light that connects to main supply line on injector pump it says if light come while accelerating to changed fuel filter done that light still comes on under load says to check lift pump next what do I check or maybe how do I check it? Thanks for any help.
I am assuming that light comes on when there is very little to almost no fuel pressure. If replacing the fuel filter is not improving the fuel flow enough. Your LP is not moving enough fuel.
Do you have a programmer of any sort on your truck?
no sir everything is stock.
I know the stock LP can not keep up many programmers. My old '01 could pull the fuel pressure down to close to 0 PSI with even a short [1 or 2 seconds] WOT throttle blast.
After the first test drive when I discovered that I did not use the programmer till my after market Airdog LP was installed. After that I couldn't pull it under 20 PSI ever at WOT unless the filter was getting dirt and flowing less.
If you are not getting enough fuel PSI with a stock motor, I am guessing you have a partially clogged or blocked fuel line issue, or your stock LP is weak.
