Introduction.....with a question...
Old Jul 16, 2007 | 07:46 PM
TNLoneWolf's Avatar
Smile Introduction.....with a question...
Hey guys, TNLoneWolf here (new member). I was just looking around the web today, trying to find a little information about EGT probe locations, and found this site. I bought a used 2005 Dodge Ram 2500 4x4 CC SB about 6 weeks ago, after spending the last 7 years driving Fords. I really don't know a great deal about the Dodge's except the Cummins engines are supposed to be first rate!
I installed EGT probes into an aftermarket exhaust downtube of both of my Ford trucks, but this Dodge didn't require a new downtube and the Banks kit I bought instructs me to drill a hole into the manifold on the Dodge I now have.
The area to work seems a little too tight for a drill motor and a 7/16" drill bit also. Also are there any pre-drilled holes in the factory exhaust manifold that could be used? Thanks for any help you can give.
Old Jul 16, 2007 | 08:09 PM
CTDinMT's Avatar
I drilled my manifold just forward of the collector. Right on top, basically in the middle between cylinders 3 & 4. No pre-tapped holes on a Cummins (unless equiped with the Jacobs, which would be post turbo). You want to run pre-turbo rather than post for the most accurate idea of whats going on in your engine. Easy to drill, tap and I stuck a small magnet in the manifold to get the chips. Any chips I didn't get blew safely out the exhaust side of the turbo and out the back.
Old Jul 16, 2007 | 08:58 PM
duallydave's Avatar
Talking
hey welcome to the site,this place rocks,there are some real smart dudes here that can answer any questions u have.u made the right choice on the dodge and this site.u should be able to get a cordless drill in there and some guys say put some vaseline on the bit just before it goes thru.then get a vacum cleaner and tape a small pipe or somtning that will fit in the hole ontl the nozzle and suck out anything that may have gotten in there.same when tapping,use some vaseline on the tap and take ur time.
Old Jul 16, 2007 | 09:10 PM
isbeinside's Avatar
i put mine on the #6 cylinder runner where it bents down to the collector, its suppost to be the hottest cylinder?.
Old Jul 16, 2007 | 09:19 PM
mudslinger's Avatar
I put mine by the #5 cylinder as the back ones are supposed to be the hottest. A little back of the collecter also helps to make sure you don't drop any shavings down the collector before you can suck/magnet them out. Good luck you should really enjoy this one after playing with Fords!
Old Jul 16, 2007 | 11:16 PM
JOECUMNS's Avatar
TNLONEWOLF, couldn't find info in your bio, what part of TN are you in?
Old Jul 17, 2007 | 04:19 AM
own1bigtruck's Avatar
a 90 degree drill, or drill adapter will also make your life a whole lot easier! Learned from experience.
Old Jul 17, 2007 | 06:22 AM
TNLoneWolf's Avatar
Hey Joe, I live in Hendersonville, but run all over the local Davidson County area on my job. Thanks for asking!
Old Jul 17, 2007 | 06:25 AM
TNLoneWolf's Avatar
Thanks everyone for the advice on location and installation, I'm towing my family and 5th wheel to Gulf Shores this Friday. Maybe I'll get the probe installed before then.....
KAyers
Oct 21, 2006 06:23 PM
Thrust
Sep 15, 2004 12:14 PM
cinnabar
Jan 26, 2004 08:44 PM
GTSDave
Dec 14, 2003 11:29 PM
BlackMtnDiesel
Nov 25, 2002 11:07 AM
