Internal Engine Upgrades
Old Jan 16, 2004 | 10:48 PM
Lambo's Avatar
Im fairly new to diesels and cumminse so excuse me ignorance. If i was theoretically going to push the horsepower limits for racing (800 - 1000HP) what internal engine upgrades would i need? such a pistons, heads, camshafts, crankshafts? Also would the rear ends handle that much horse. I do realize engine upgrades would be needed.
p.s. im reffering to a new common rail engine, not my pickup
Old Jan 16, 2004 | 10:50 PM
Lambo's Avatar
oops
I meant i know transmission upgrades would be needed not engine.
Old Jan 17, 2004 | 07:42 PM
belfert's Avatar
Re: Internal Engine Upgrades
From what I've read, an older 12V or 24V would be easier to upgrade to the horsepower you want. The truck would be cheaper too.
Brian Elfert
Old Jan 24, 2004 | 10:51 AM
BADBOWTIE's Avatar
I don't know if anybody has been able to push a cr cummins anywhere near that high yet. You have to control timing to get numbers that high and we are still waiting for our timing boxes. These diffs are new to this body style so nobody has pushed them that high either. Brian might have the best suggestion, if you want that kind of power a 24 valve would probably be better,but nothing making 800hp is going to be cheap.
Jason
Old Jan 25, 2004 | 01:12 AM
Vaughn MacKenzie's Avatar
The only way to make that HP is with a P-pump from a 12-valve, which I've heard someone has done already.
Internally to go 800+ HP requires O-ringing the block or head, significant head porting, possibly upgraded valves, camshaft, and ceramic coated marine or RV pistons (or the stockers). Some use a mains girdle too or at least a stud kit for the mains in addition to the head.
Stock rods and crank should be fine.
Vaughn
92smokin blacky
Nov 26, 2009 11:13 PM
rdavisDGM
Feb 5, 2008 12:16 PM
DodgingTools
Apr 25, 2005 08:03 PM
Commatoze
Apr 28, 2004 08:04 PM
zspear1
Jan 23, 2003 08:52 AM
