Installing coolant heater...have a few ?'s.
I bought a 1500 watt inline coolant heater today.
It says to tie into the coolant by the bottom radiator hose, run a hose to the input of the heater and then run a hose from the output side of the heater back to the engine.
I looked and can see where there is a fitting just above the bottom radiator hose where the hardline heater pipe goes in behind the exhaust manifold and then goes up, turns to a rubber hose into the heater core...then back out.
What I am wondering is what would be the best way to tie into this?
My concerns are that if I route the coolant from the fitting at the bottom front out to the heater, should I route it right back there or should I tie it in further downstream towards the firewall? It might be a tight fit or a no go if I try to plumb it right out and back in. Or maybe there is a plug on the block I can use for supply and then use the ' Y ' [optional piece] fitting that came with the kit to plumb into the heater hose somewhere else?
Just want to make sure I am not plumbing a problem.
Spoke to the dealer about warranty...of course the only issue would be a leak.
That is not my biggest concern.
Thanks
Scotty
Thanks
Scotty
I have a block heater and may run both. The block heater in -25 to -40 temps does not generate heat for the cab and it needs to warm up for quite awhile.
The coolant heater circulates the heated coolant through the heater core and the engine.
Berak, that is what I will do.
Thanks
Scotty
Thanks
Scotty
I should add that the actual heater itself is located about level with the bottom of the engine. I think Espar recommended it be lowest point possible in the coolant circuit.
It's kinda funny, but for some reason my wife only likes to drive my truck when it's freezing out and she's working a late shift.
Good luck with it.
Good luck with it.
Good luck with it.
Good luck with it.
Scotty
Scotty,
What point did you use to pick up coolant for the heater? Instructions state the pickup should be low on the block or from an optional splice kit for the lower radiator hose.
The largest lower hose splice isn't large enough for our engines.
Originally Posted by 300 SDL
Scotty,
Scotty
For I D I was going to mic the O D and hose thickness. Subtract 2x hose thickness from O D for I D. We are only dealing with rubber. Clamp the splice with nipple in place in the lower hose. Run hose from nipple to coolant heater intake.
All we need is someone to fab the splices. Should be fairly inexpensive. I am surprised more owners are not looking for a better coolant heater. The block heater only warms the coolant.
Have not done it yet.
I am eventually going to get fittings from the folks that supply my fuel kit parts...The owner is away until next week. I am told there is a pipe nipple that will clamp into the bottom radiator hose. I will weld a fitting to this to supply the heater, then run back from the heater to the hose right by the oil filter with another 'T'. At least that is my theory for now until I get some parts in front of me.
Scotty
Scotty
