Installing a BullyDog OutLook
Old Nov 19, 2005 | 08:11 AM
SmokenRam's Avatar
Has anyone Installed the outlook monitor. I just got done doing one on my 05 and it won't come on. I have everthing hooked up ecept for one RED connector, I'm not sure where it goes, the direction don't help me out too much eather. Any help would be GREAT!! Thnaks, Chris
This is the red conector, Does it do anything??
Old Nov 19, 2005 | 08:51 AM
SmokenRam's Avatar
And also when i start it, my check engine light come on, when i check the codes with the triple dog, it says "p0237BoostLow" What going on here??
Old Nov 19, 2005 | 09:58 PM
AK RAM's Avatar
I believe that would be for power, which would explain why it is not coming on, but I have no clue where they prefer that you connect it. The Outlook also plugs into the MAP sensor (boost sensor) and the stock MAP harness plugs into the Outlook. Since the Outlook is not powering on, the MAP signal is being cut, giving you the low boost codes. Just need to find the correct power source for the red wire and everything will be fine.
Old Nov 21, 2005 | 09:43 AM
SmokenRam's Avatar
Hey thanks, I'm calling bullydog today, It is for a hot but not sure where it goes??
Old Nov 21, 2005 | 12:49 PM
hognutz's Avatar
I would read the directionls but my guess is that red wire needs 12v. I bet once you supply the voltage the monitor will come on.
It should say if that wire is 12v switched or 12v battery. that will let you know where you need to tap.
RyeThomas
Mar 9, 2007 01:14 PM
coobie
Jul 24, 2006 06:46 PM
essgeetee
Jun 3, 2006 12:24 AM
razor6
Apr 21, 2006 04:59 PM
quantrill88
Oct 4, 2004 11:36 AM
