Installed rail pressure gauge....No Workie..
Old Jul 11, 2007 | 08:00 PM
Checkmate's Avatar
Angry Installed rail pressure gauge....No Workie..
I got the Quad rail pressure gauge in the mail today. I hooked it all up and have no indication of life to it.
I checked the positive connection and I am getting 12 volts and the ground is grounded well, BUT yet no display of any sort when key is on, off, run, etc.
Anybody else ??
Old Jul 11, 2007 | 08:13 PM
Billy Ram's Avatar
Did you hook the right wire to ground? The long wire in the split loom is for the fuel pressure.
Old Jul 11, 2007 | 08:34 PM
Checkmate's Avatar
Yeah I belive so. I thought maybe not, but I double checked and it is the black wire coming out of the harness with the large ring connector whereas the other wire was dark grey with a slightly smaller ring connector and it has it's own wire wrap....Correct ??
Old Jul 11, 2007 | 08:41 PM
donhov's Avatar
There was another post concernign a problem and quad answered, something about an insulator ring and it's location. Sorry I don't remember information but I'm sure if you do a search on the subject you can find the posts.
Old Jul 11, 2007 | 10:40 PM
Checkmate's Avatar
I looked through all of quads posts since these first got sent out and can't find anything ....?
Old Jul 11, 2007 | 10:45 PM
vzdude's Avatar
DTR's 'Go to Guy'
The insulator ring is on the sender itself ( for the lift pressure ) . You aren't getting any display at all? or no readings?
Old Jul 11, 2007 | 11:02 PM
qzilla's Avatar
Check the fuse and or the fuse tap itself and make sure it is getting power to it.
Worse case scenario the 3 LED's above the buttons should be lit up when power and ground are connected.
Old Jul 11, 2007 | 11:03 PM
06CTDforAU's Avatar
Sounds like you could have a bad display. I know that doesn't make sense because Quad says they test everything before shipment, but sometimes things do slip through. He was on earlier tonight; have you PM'd him? That might be the best thing you could do at this point and give them a call tomorrow.....
Old Jul 11, 2007 | 11:04 PM
06CTDforAU's Avatar
Looks like I was a little late...... I figured he would show up in this thread.
Old Jul 11, 2007 | 11:13 PM
qzilla's Avatar
Blackberry's rule!!!! Just finished a softball game and now we are eating good in the neighborhood!!!!
Old Jul 11, 2007 | 11:16 PM
53 willys's Avatar
Hats off to you Quad!!! giving customer support while your out to eat is above and beyond!!
Old Jul 11, 2007 | 11:18 PM
vzdude's Avatar
DTR's 'Go to Guy'
How do you do it all quad!?!? You need a couple of clones!
Old Jul 12, 2007 | 01:26 AM
qzilla's Avatar
I just thought of one more thing and it is the only other possible thing at this point.
If you 100% have power and ground and the 3 LED's still are not lit at the least then the only other thing it could be is a bad or broken solder joint where the harness goes into the board. If you want to check it then its ok with me. Just remove the 2 screws on the back and you will see the wires going into the board. The red is power the black is ground. If one of the solder connections are broken that is your problem. It should not happen but, it has.
So at minimum with power and ground you will always get the 3 leds, I don't care if you take the microcontroller off, those 3 will work as they are tied directly to power and ground.
Old Jul 12, 2007 | 02:36 AM
qzilla's Avatar
Whats he deal??? I need to know if he fixed it!
I mean really what is he doing right now.....sleeping?????
By the way.....YES I AM KIDDING!
I just hate it when stuff does not plug in for someone and work like it is supposed to.
I can't sleep until it is fixed!!!
Old Jul 12, 2007 | 04:21 AM
madhat's Avatar
Administrator/Jarhead
I got mine yesterday, BTW. Hopefully I get it installed today, if I'm lucky...
