Installed BD Pup stacked w/ TST today
Old Nov 14, 2004 | 04:29 PM
Fummins's Avatar
Originally posted by midwestdually
so i thought of something else...the box is either on the 90hp or 130hp setting...no incab controlling correct>>hmm
Yes and no........a new program can be loaded in 8 minutes from inside the cab at the OBD2 port.At least it can in my truck...
Old Nov 14, 2004 | 05:40 PM
WhiteSport600's Avatar
DYNO RESULTS:
BD PUP Extreme, TST off
Max Power: 349.2@2950RPM
Max TQ: 766.6@1900RPM
BD PUP Extreme, TST 3/4
Max Power: 455.4@2950RPM
Max TQ: 919.7@2350RPM
BD PUP Performance, TST 7/7
Max Power: 453.2@2950
Max TQ: 898.8@2100RPM
BD PUP Stock, TST 8/8
Max Power: 465.1
Max TQ: ???? It seems the tires were spinning on the dyno as the torque curve is really messed up...
Old Nov 14, 2004 | 06:00 PM
JamesP's Avatar
Power PUP other levels?
Cool! TST still doesn't have any competition..
Do you have stock, Tow and Performance settings for the power pup w/ TST off also??
Old Nov 14, 2004 | 07:38 PM
midwestdually's Avatar
so with the BD pup OFF....and the TST on full power you saw the 465hp numbers?
Old Nov 15, 2004 | 09:50 AM
The Bully Dog was completely off and the TST was at the 8/8 setting. It goes to 9/9 but the dyno wasn't holding the torque very well. The rollers were looking pretty bald, and I couldn't get anybody to sit in the bed due to the smoking
Old Nov 15, 2004 | 10:00 AM
Re: Power PUP other levels?
For driveability, the Bully Dog is king. But in a performance only situation TST def. makes the most. I drive around with the BD on extreme and if I get into a race on the highway and need more I'll turn the TST up to 2/2. It's a pretty good combo, but I only need it when I'm racing the faster stuff. Never needed it for a PowerJoke or DuraJap
Old Nov 15, 2004 | 10:48 AM
cquestad's Avatar
TST will do 200hp or more over stock with the right turbo...got to love that lil' box!
Old Nov 15, 2004 | 11:23 AM
Yeah, I can't wait for the B1-04 #'s
Old Nov 16, 2004 | 10:11 PM
i still dont understand a box that is supposed to have 130hp on extreme only puts out 355 and a box that is the same puts out more than what it is advertised at?? the 04.5's are on the average between 270-285hp stock at the rear wheels correct??
please help me understand
thanks
Old Nov 17, 2004 | 07:32 AM
sawboywv1's Avatar
WhiteSport, Do you have an Auto or 6 speed? I can't believe you were not spinning the clutch in a 6 speed with those numbers? Regarding a Auto.... I thinks it would be toast by now as well!
Old Nov 17, 2004 | 08:30 AM
TUGUM's Avatar
what kind of egt's
Old Nov 17, 2004 | 10:04 AM
It's a 6spd and I have the Con OFE clutch that's rated to 450hp. It wasn't slipping. The dyno rollers only weigh 3600lbs so it's much easier on the driveline than flogging the truck while going down the road.
The highest egt's got was around 1430. The Bully Dog doesn't make near the egt's the TST does...
Old Nov 17, 2004 | 10:25 AM
Don M's Avatar
DTR Advertiser
Where and what type of dyno did you use?
Good numbers BTW!
Old Nov 17, 2004 | 11:33 AM
Thanks DonM, The dyno was a Dynojet 248C I chose it just because I've got alot of experience with this dyno and know the owners quite well. And I pulled the truck in 6th of course...
Old Nov 17, 2004 | 11:39 AM
thanks
Actually I never baselined my truck without any fuel box on. The Bully Dog did it's job quite well as it is rated at 130hp. These trucks have around a 30% drivetrain loss so you can count on 450 flywheel hp with the BD alone. The TST is rated at much more however. It is said to be 20hp per level and 50lb/ft on the tq side. Which equals 200hp and 500lb/ft. Pretty accurate actually...
