Inline 6, V8's OOH! "Inline 8"
Old Mar 28, 2006 | 08:22 AM
Javahjoeo's Avatar
Years ago, my dad gave me a 1941 Buick, Coupe, 3 speed, stick. That car was a dream to drive. It was my first car, (at 15). That Buick would run all day at high speed. However, it would take it a long time to get there. Just put the pedal to the metal and leave it there. I never could get it wide open. (Long stroke engine) I put 3 carb's on it and it would just keep picking up speed. I loved that Buick. Could there be an 8 cyl diesel out there, just looking for a Dodge??
Old Mar 28, 2006 | 02:54 PM
nickleinonen's Avatar
inline 8 diesel in a high speed diesel application isn't the best design.. the inline 6 for a high speed diesel is only bested by a v12 for balance..
[high speed diesel is anything over ~1,000rpm, med speed 100rpm~1,000rpm, low speed >100rpm]
Old Mar 28, 2006 | 04:02 PM
HOHN's Avatar
Wanna bet whether an inline 6 or V12 is cheaper to make or more reliable (due to complexity)?
I'll take the 6, thanks.
Old Mar 28, 2006 | 04:06 PM
RustyJC's Avatar
As inline engines get longer and longer, the torsional stiffness and torsional resonant frequencies of the crankshaft (and even the camshaft) become problematical.
Generally my employer would build inline 4-cycle power engines up to 8 cylinders and then go to the V configuration for 12, 16 and 20 cylinder engines. We did build some V-8 locomotive diesels, however.
Rusty
Old Mar 28, 2006 | 04:08 PM
Geico266's Avatar
The I8 would be very long. You could rest your coffee cup on #8 valve cover.
Now, if we make them opposing cylinders and lay them 90 degree on the side we could shrink the lenght back to a managable size, but now we have the heads sticking out the fenders!
Old Mar 28, 2006 | 04:45 PM
mikmaze's Avatar
well now, torsional load could be more easily spread if yu take the drive power off the center of the crank, between the front four and the back four cylinders, a gear drive low slung output. this gear would be part of the crankshaft, and double as the harmonic balancer. also driven off the center off this same gear cut on the crank, would be the cam, thus reducing torsional forces in this item. "cmon roll with that idea a while.......
Old Mar 28, 2006 | 07:57 PM
rammtuff's Avatar
Just like the inline 6 diesels in the early 70's Dodge highway tractors. The short hood ones had 3 cyls in the passenger compartment. Kept your lunch warm.
C Schomer
Feb 16, 2009 10:38 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Gear Poet
May 8, 2004 02:15 AM
hellotbone
Jan 27, 2004 08:22 AM
Mostwanted
Jul 11, 2003 10:12 PM
