Injectors Or Programmer
Old Mar 31, 2007 | 12:03 PM
K RUSSO's Avatar
Does Anyone Recomend Anything For One Of These To I Allready Have A Edge E-z Which Works All Right But Im Not Real Crazy About Electics And Wiring I Also Airaid Intake And 5 Inch Straights
Old Mar 31, 2007 | 12:54 PM
Mav's Avatar
Mav
Id get a programmer first
Old Mar 31, 2007 | 02:24 PM
omaharam's Avatar
A downloader or control module will both give you more bang for the buck than injectors. Also, downloader = 5-6 minutes, control module = 30-60 minutes, injectors = several hours and cannot be changed back easily.
Old Mar 31, 2007 | 06:36 PM
acook's Avatar
Definatly a programer. You can get more power from a programer then you can with just injectors. A programer is less then half the cost of injectors, and many programers have a ton of features, for example on my bullydog you can:
remove tq management
add low end power
read codes
enable ide control with cruise control buttons
adjust how long your accessories stay on after you remove the key
enable the use of fog lights and brights at the same time
enable/disable auto door looks, seat belt chime etc...
Old Mar 31, 2007 | 06:49 PM
Floorman's Avatar
injectors take less than an hour to install . however boxes give you just as much power and are easier to install.
Old Mar 31, 2007 | 06:55 PM
acook's Avatar
trust me, a first time injector install will NOT take less then an hour.
Old Apr 1, 2007 | 04:01 AM
ramtd02's Avatar
Agreed, on a 12v or 24v....on a CR your looking closer too 2-4 hrs, depending on experiance. And we do not replace the injector on our trucks, we pull the injector, swap nozzles, and replace injector.....a set of injectors for our machines is close too the 3000 mark (stockers). Plus the cost of nozzles!!
Old Apr 1, 2007 | 04:03 AM
ramtd02's Avatar
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
