injectors??
Old Mar 9, 2008 | 12:43 PM
N8theGr8's Avatar
injectors??
looking for some pretty intense injectors of an 04..
any ideas
thanks nate
Old Mar 9, 2008 | 12:50 PM
bluechrome's Avatar
One Name DON M! F1 Diesel. I bet those injectors will be the first to get a common rail to 1000hp on #2 only!!!
Old Mar 9, 2008 | 01:24 PM
desertchecker's Avatar
x2 on don m fluxs
Old Mar 9, 2008 | 02:10 PM
Jetpilot's Avatar
As mentioned above F1 is the pinnacle of the injector. That said when choosing a CR injector having the fueling mods to support a large injector is as important as the injector itself. Running a large injector with a stock Cp3 wll actually reduce HP and increase heat than a smaller injector. Hence thats why if you look at F1's site you will see the need to a modded or dual Cp3 for anything above flux 2's.
Doug
Old Mar 9, 2008 | 03:19 PM
Snapoff's Avatar
Doug
X2!
The flux 2.0's should get you the better part of 700hp with the new Smarty TNT.
I ran the Flux 2.5's and the rail pressure would fall on it's face with a single modded CP3.
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
