injector removal
Old Jul 17, 2008 | 10:03 AM
goodeyesniper75's Avatar
injector removal
So i have narrowed down my engine issues to a bad injector. I have everything taken apart but im having a hard time pulling the injector out. Its #6 cylinder of course so its hard to get to. Any ideas on how to pull that s.o.b. out?
steve
Old Jul 17, 2008 | 10:07 AM
dodgezilla04's Avatar
you have the connector tube removed completely? then once the 2 screws that hold the injector into the head are removed, just grab the injector body with a rag, and pull up. you can wiggle side to side as you pull. there is an oring that seals the body in, which you are fighting, and probably some carbon on the tip that is helping keep it in the head. dont forget about the copper sealing ring at the tip end.
Old Jul 17, 2008 | 10:09 AM
Dwitt0187's Avatar
i used a brake adjustment tool to get mine out but if you can barrow the injector tool it would make it alot easier. but if no tool just use a screw driver and bust a couple knuckles it will come out you do have the bolts and tube out for sure??
Old Jul 17, 2008 | 10:12 AM
0lywrench's Avatar
i had to loosen the bolt that holds the tower in place and move it a hair,it was some how blocking the injector hold down flange,once i did that it came right out
yes, both bolts are out, i almost forgot about the tube but did remove it. I am trying to find somone with the tool but i will probably end up just man handling it out of there.
Old Jul 17, 2008 | 10:40 AM
RyeThomas's Avatar
Winner winner chicken dinner!
Most will come out by hand but if they dont I use a very small pry bar. I mean this thing looks like I bought it at Toys R Us, but the pry end fits perfect under each side. I gently pry each side a little, try to keep it even and they pop right out.
Im all for using the proper tools but sometimes you got to get work done. This has worked for me all 6 or so times I have pulled my sticks. Good luck.
Old Jul 17, 2008 | 11:51 AM
if it was one of the other cylinders i wouldnt have an issues but because its the back one its hard to get at.
Old Jul 17, 2008 | 08:16 PM
does anyone know where i can get one of those injector pullers? the miller 9010?
Old Jul 17, 2008 | 08:34 PM
homewrecker's Avatar
That back one is a pain!Try laying a wrench flat on the left side of the head(lay it inline with the outer row of head bolts).Use a long screw driver as a pry bar.Put it under the bracket that holds the injector down and lay it across the wrench and push down. The wrench will act as a pivot point.This worked very nicely on the back 2 when I did mine 5 different times LOL!
Can't help on the tool.Good luck.
Old Jul 18, 2008 | 06:55 AM
wap's Avatar
wap
I used a wonder bar and mine popped right now, I would think any 90* prybar that will fit in there would work.
Old Jul 18, 2008 | 12:59 PM
madhat's Avatar
Administrator/Jarhead
I am too going to be doing this soon, for the first time. Someone just posted a weld free injector remover in the DTR Photos...
Old Jul 18, 2008 | 03:56 PM
Im not a member of the pay to play site. could you get the pic and post it here?
Old Jul 18, 2008 | 08:24 PM
CoolumConst's Avatar
I used a screwdriver and pryed up under the holddown bracket.
HUNTINNUT
Jul 27, 2013 11:40 AM
trik396
Jun 1, 2008 07:04 PM
kawi600
Jan 26, 2006 10:19 AM
thumbs
Oct 29, 2003 02:19 PM
GreyBoy
Oct 22, 2003 06:12 PM
