Injector Install Question
Call this guy, I got my stuff from him http://www.mumaudiesel.com/ guys names Jeff if I remember, dude has any and everything for the cummins engine, from stock to aftermarket and his prices are better than Cummins.
Man, I swear I dont ever need to work on my truck again, but I went to install springs and studs, so the injectors came out, well...
I went to start and a lot of white smoke (expected) but the thing sounds and feels like its got a monster cam in it, it shakes and feels like a top fuel nitro car. So is this from over tighting the connector tube or what? Because I followed the DDP website injectors install PDF, but as you can tell I screwed something up. Also there is a nice sounding knock coming from the engine.
Runs like a champ now even though I swaer it has a little more injector knock than usual even though the local performance diesel guy said it sounds fine, but I did throw a code the other day, p0148 High pressure CR, but it had know power loss or running different at all, I cleared it and 400 miles later it still hasnt throwin the code
When taking off the air horn/heater grid to get to the inj. tubes, are the gaskets ok to re-use?? Or do I have to remove the air horn/grid??
I'm prepping to get ready to install new inj.and this is according to DDP inst., if I'm reading it correctly.
The air horn and grid heater both have to be removed completely. Given how inexpensive the gaskets are (~$10 at Cummins, IIRC), I would get new ones. No need to risk a boost leak for $20 worth of gaskets.
Txbigfoot
Apr 3, 2014 11:12 PM
blackjet2500
Mar 18, 2009 11:26 PM
oscaroc
Apr 2, 2005 12:14 PM
