Injector down- Time for upgrades
Old Sep 16, 2011 | 07:55 AM
wshamby01's Avatar
OK guys I have an 03 with 270k on the clock and finally lost an injector so time for upgrades. Just looking for suggestions to my list. This truck is used to tow heavy all summer in the hay fields. I need to keep EGT's in check but do not want to go to twins. Any ideas appreciated.
Current mods
TS Performance Ramifier
AFE intake
4" exhaust
Boost and EGT gauges
Fresh NV5600 from Blumenthal's
South Bend DD3250
Mods to add
Fass or Air Dog
Industrial Injection 33% CP3
Industrial Injection 100hp injectors
ARP studs
New head gasket (just in case)
Cam, Springs, and lifters
Garrett Powermax Stage 2 or 3 depending on recommendation
Exhaust manifold if needed
Old Sep 16, 2011 | 10:19 AM
89dieselkong's Avatar
If your looking to tow heavy and are worried about EGT's I probably wouldn't be adding all that extra fuel that you are. I added 50HP injectors just because they were cheaper and have battled EGT's issues since. Bought the Smarty Jr. to help with those (which it did) and now might need a new turbo. I would stay with stock injectors or small ones at best and a good tuner. That should pull fine for you (I a pull 12,000lb 5th wheel) and keep some money in the bank as well
Old Sep 16, 2011 | 09:04 PM
wshamby01's Avatar
I am not worried about egt's I just want to keep them in check without twins if possible. I did have a Bully Dog power pup stacked with my TS Performance box so I know plenty about managing egt's with the pedal and gears. Now that this is not a full time work truck it is time to have a little fun. We tow trailers around 30000 pounds loaded with hay.
Old Sep 22, 2011 | 03:06 PM
wshamby01's Avatar
On order is a Smarty- POD, Garrett Powermax Stage 2, and II 60hp injectors. Decided not to go all out.
Old Sep 22, 2011 | 04:14 PM
soulezoo's Avatar
DTR 1st Sergeant
^^^ should be a good fit.
Old Sep 22, 2011 | 04:45 PM
AH64ID's Avatar
I agree that it should be a good fit. 50-60 hp injectors are what get the best reviews for towing, 90-100 is too big.
Old Sep 22, 2011 | 06:51 PM
wshamby01's Avatar
Got the Smarty from here. The turbo from Tom at Turbo resource. The injectors from TC Diesel. Now if they will just hurry up and get here. Hope to install not this weekend but next weekend.
Old Sep 22, 2011 | 06:57 PM
wshamby01's Avatar
Here is one of our smaller loads on my 2011. 23 bales. Some of these are only 4 x 4.5 or so instead of 4 x 5.5 so that makes them quite a bit lighter. The big ones can easily weigh in at a 1000lbs each depending on type of grass and how dry they are.
Old Sep 27, 2011 | 07:33 PM
wshamby01's Avatar
Turbo and Smarty are here so far. Still waiting on injectors. I am new to Smarty. Does anyone have any ballpark settings for it.
Smarty S Pod
Garrett Stg 2
60hp II injectors
I have a SB DD clutch so I think I have that covered.
Old Sep 28, 2011 | 05:44 AM
AH64ID's Avatar
For towing SW3 TM3 TQ2 RP1
For play SW5, rest the same.
You will just have to see where you sit for EGT's and what your comfortable with.
Loosewire
Jun 5, 2012 11:24 PM
dodgeman5902
Jan 10, 2010 03:05 PM
Stovetop535
17
Jan 31, 2008 11:40 AM
TAS
Oct 14, 2007 09:40 AM
RamWheelsBy4
22
Jul 13, 2005 06:51 PM
