I dynoed my truck yesterday @ Scheids.....
Old 08-28-2007, 06:23 PM
  #61
haloman's Avatar
Originally Posted by rynemurch
Are we going to go or is it to soon to make a answer
Look in the Chapter Disscussion Thread....
Old 08-28-2007, 06:27 PM
  #62
Sapps's Avatar
Originally Posted by Don M
Get water injection and a big tank if you are going to tow. It'll save you lots of cash and time later on down the road.
Valve seats, melted pistons, everything. I see this stuff all the time. Maybe cuz I see so much of it Im freaked out, but I hate to hear guys needing to replace engines when water would save em.
Don,
Just got the Coolingmist Stage 2 EGT Kit installed with 12G Tank yesterday!!!!
Towed 200 miles today...WORKS GREAT hasnt gone over 1200 yet !!!
Hey Don did you get a chance to check out my failed stock injectors yet? Curious why they failed. Thanks
Old 08-28-2007, 06:29 PM
  #63
cquestad's Avatar
What triggers your flow? I want to do the same thing.
Old 08-28-2007, 07:26 PM
  #64
SmokinDodge12V's Avatar
Is your truck a 555 engine? if so, that is great power with as single turbo on a DynoJet!!
Yes his is the 555 motor.
Old 08-28-2007, 07:40 PM
  #65
DTR Advertiser
Don M's Avatar
610 is great then. Not many 555's go over 600 with a single. Not many at all, and not many on a DynoJet
Old 08-28-2007, 07:46 PM
  #66
Sapps's Avatar
The controller is set up to activate progressively on EGT (Min) and 100% Pump DC will be at (Max) EGT. The controller is also boost referenced for safety, it will not inject unless it sees 5lbs min. So basically you just set the 2 egts ***** min and max. I have it start spraying it at 1000 and full spray at 1200. Clear as mud?
Old 08-28-2007, 09:58 PM
  #67
W.F.O.'s Avatar
I guess your injectors are doing the trick! I would like your guess on where to set the electronics on this thing, TST,BDDL,&Ramifier. I can't believe that where i had things set, actually was that close to max power. But i really know very little when it comes to the settings.
Old 08-29-2007, 10:05 AM
  #68
cquestad's Avatar
I want that...the $600 dollar Cool Mist Kit then?
Water here I come...
Old 08-29-2007, 10:42 AM
  #69
PourinDiesel's Avatar
Don's right. I also think his injectors as well as twin pumps are what makes your truck put out the 600+ numbers. Of course the 66 helps
I didnt even use my TS box for the dyno runs...still 90hp tips!
Old 08-29-2007, 10:45 AM
  #70
cquestad's Avatar
Come one...lets not blow too much sunshine!
Good electronics, stock CP3 and injects, coupled with an A5k took my truck to 575 hp.
If I only had a stage 1 or 2 pump...600+ would have been easy back then.
Falcon1
06-11-2008 05:23 PM
white250005
13
01-08-2008 05:40 PM
53 willys
48
09-10-2007 06:44 PM
omaharam
15
01-30-2007 09:46 AM
Dieseldude4x4
49
08-23-2003 07:22 PM
Quick Reply: I dynoed my truck yesterday @ Scheids.....
