HVAC Temperature Control Panel/Switch
Old Apr 11, 2014 | 12:50 PM
MattLFerguson's Avatar
Heater Control Panel Light
After putting in a new seat heater switch, the Light on the Heater Control Panel is out. It is only on the **** for the Fan Speed and Discharge (floor, defrost, etc.)
Since I had to pull the Bezel off to replace the seat heater, I thought that maybe a connection had come loose and that was the issue. So I pulled the bezel out again and double check the wire and they look good.
The lights for the Temp Levers and Defrost Button work just fine, it's only these two *****.
Anyone have any thoughts?
Could it be that why I snapped the bezel back the first time that I jolted the lights in the switch enough that they burnt out?? This would mean I would have to replace the whole Control Panel.
I found the part number for the Control Panel and for my 2006 it is Part # 55056570AD
However, I have found the part number for the 2008 to be 55057080AA.
Since they are the same model and gen truck, would the parts be the same??
I ask this because the 08 part number is cheaper.
92smokin blacky
Sep 1, 2010 09:55 PM
04ctd
Nov 22, 2007 08:46 AM
ganodave2
Oct 29, 2007 12:38 PM
rvluversnc93
Mar 5, 2007 04:12 AM
tom.jelly
Nov 10, 2006 02:04 AM
