HTT 62/13SS Going in Sat.
How much faster did it feel w/just the turbo install? Were you running the Smarty Sr. with the stock turbo? I thought the better turbo would make less smoke. Any idea why it smokes more?
Thanx.
Thanx.
I didn't dyno with the stock turbo. I know my drive pressures were too high with a 9cm. exhaust housing. The smoke is due to the larger turbo not spooling to the same level down low. The stocker would spool to 20# allmost instantly with that stack, but it wouldn't flow enough air up top. I was hitting 1380* in 10 seconds with the stocker going up a small hill @ WOT. Now I haven't been able to get it over 1250* & with the Jr. on 100 alone, I had trouble getting over 1000* I think the Sr. with the aftermarket turbo, stock inj. program will be the ticket.
I tryed the Jr. on 70, & put the XZT back on, & gave it a try. No dyno #'s for you, but it still runs pretty good, & low end smoke is less. I'd guess, It's giving me about 425+/- hp. this way. Still haven't had the chance to load the camper, & try some heavy loads either. Will be loading up for spring turkey in Apr. Got 3 mountain passes to cross to get there. So far the turbo has allmost eliminated my top end smoke @ WOT. Once it's spooled up. Definitly a tad slower to spool than the stocker. It would blow up to 25-30# allmost instantly. The HTT spools about like a stock truck with stock power. Maybe a touch slower. I'll be very happy if the Sr. I ordered with the aftermarket turbo program stops my bottom end smoke. SW#9 with that, & stock TQM put down 429/800 on the dyno. I think it would do a few more with a couple more runs. I don't think the turbo was spooling all the way in the short time it had. For what I want, I'm glad I didn't go for the 62/71/14ss. I'm sure that would have been a mistake for me.
Just an update to ya'all who wanted to know. I loaded my camper today, & gave 'er a run up a hill. I started @ the bottom, & floored it. Belched smoke through 1st gear, cleaned up through 2nd. Locked the T/Q @ 60 mph, & hit 70 mph by the top, & here's what I saw.
Boost hit 40#
EGT's only hit 1256*
Once the turbo spooled up, there was allmost no smoke @ WOT. This was with my Smarty #9 Aftermarket Turbo/Stock Inj. program. The truck weight was about 11.5K#
Boost hit 40#
If you opted for the tightest TC then that is why it is smoking a little in 1st. Not enough RPM to spool the turbo up enough. I got the 71 turbine and Lmills was kind enough to tell me to get a little looser TC or it will not be fun loaded starting off. I hope to order my parts next week. Yepee!!!!! Also, if you change the TM from stock it will help with the Smarty Sr. so I have been told. We shall see......
You may be right about the TQM. I had it on mild at first, & it smoked off the line too, so I put it on stock, but that didn't change anything, or not enough to notice. I'm going to try the moderate next, & see what happens. I don't think anything will realy change the low end smoke. When I got my trans, I was happy with just a Quad XZT. I should have known better.
I am glad I saw this thread. BigWheels, you and I have the same truck configuration and almost the same exact mods, except for your built tranny and now your new turbo. I think with my Uncle Sam money I will be investing in a turbo and some tranny parts. Bigwheels, are you running stock injectors?
Yeah. I'm running stock injecters. I may try the aftermarket turbo,& injecter programs, & see what that does, but I'm afraid I'll lose power. It doesn't smoke that bad. More than I'm used to, but definitly not like some I've seen on here.
I think the aftermarket injector programs change the timing and you probably do not want that with stock injectors. I am not sure how much different your turbo responds than mine. If I roll the throttle on nice an easy I can leave with very little smoke. If I just step on the peddle quick running Smarty on #9 it puts out a very large cloud. Does your turbo smoke even if you roll on it easy when empty or is it just when you are trying to get the load moving? I was going to try some of the moderate or wild softwares to see if the heavier fueling down low will help the spooling.
I put the moderate TQM in this morning. Still with Atermarket Trbo/Stock Inj. & ran it with the camper on. Spools a lot faster now, but the throttle is touchy. I'll get used to that. If I roll on slowly it doesn't smoke much, if at all. If I get on it pretty good, it spools up fast, with just a good puff off the bottom. I talked to Bob today, & he's going to send me the beta 4.2 to try out. But it's not here yet.
After I off loaded my camper, I noticed right away there was more smoke down low without the load. But if I roll into it easy it stays clean. Now I wish I had tryed this on the dyno. My SOTP Gauge says it's stronger now.
Fire Rescue124
Oct 9, 2009 11:20 AM
Derek Roch
34
Sep 20, 2009 05:03 PM
Jason_K
13
May 11, 2009 08:55 AM
O.T
16
Jan 14, 2008 02:47 PM
95ram12v
Jan 13, 2008 07:48 PM
