How well does TST stack with Crazy Larry?
So I can just go to my local dealer... (That I got the TDDL from) and they will hook me up with 2.2.9??
It is my understanding that you can turn TM on or off with this tune? Is this correct? So I could still have the other benefits of Scarry Larry without the TM being deleted?
Originally Posted by Luken
Thanks Chris!!
I'm very happy with it. Next week Ill try again. I put the stacks on yesterday so hopefully they won't make me leave. lol
I have just the regular tst program and have had no trouble running the two stacked. Your right on the Te setting being the big factor. Im going to try adding some pressure after talking to several that found that the CL doesn't add very much pressure if any.
Yes I have the SCARRY Larry. BTW, If you want the Scary Larry you can't just go to your local dealer and ask for the 2.2.9 version like some have said. That is NOT what I have.
I have just the regular tst program and have had no trouble running the two stacked. Your right on the Te setting being the big factor. Im going to try adding some pressure after talking to several that found that the CL doesn't add very much pressure if any. Yes I have the SCARRY Larry. BTW, If you want the Scary Larry you can't just go to your local dealer and ask for the 2.2.9 version like some have said. That is NOT what I have.
Like he said, some elements will carry over to the newer 2.2.9 BD update. The version he and some others have is a different animal. You can call HTS to get info. In my observation, the BDDL does little pressure increase. Almost nothing in Performane; perhaps 1-1.5K addtl. In CL , I can see more; like 2-2.5K more a little earlier as well.
Chris
smoky05
22
Nov 30, 2007 08:26 PM
huntingdeer
Sep 17, 2007 09:34 PM
HeberRam
Mar 30, 2007 05:37 PM
Snojumper
34
Mar 18, 2007 12:27 PM
Warlord
20
Jun 20, 2006 10:04 AM
