HOW to test Air to Air for leaks?
Old Feb 4, 2008 | 06:25 PM
sallyman1's Avatar
I may have a possible turbo/air failure on intake. my edge juice attitude gives me 1500 egts easily even on stock setting. I narrowed it down to intake side of things.
My ? is do i put a rubber plug in hose going to intake manifold and plug off hose by turbo and install a pressure gauge and pressure up to 30lbs and spray soapy water? or how does dodge do the elaks on these things? How Do i test wastegate operation?
Old Feb 4, 2008 | 06:35 PM
Little03's Avatar
Personaly id use soapy water, Its faster.
Nick.
Old Feb 4, 2008 | 06:53 PM
Hillbilly Delux's Avatar
i know on gas engines you can find vacume leaks with a can of carb cleaner cause the engine will accelerate slightly if it sucks in the carb cleaner. but when it comes to a pressure leake and not a suction leak i think your best bet would be soapy water. block the exhaust off with it idling some how, just like an exhaust brake, that will make it boost a little
Old Feb 4, 2008 | 07:04 PM
sallyman1's Avatar
If turbo is gone can they just change wastegate or what? I dont have factory warranty any more but I have a LUBRICO 2 year warranty on truck. Will they just change turbo to a new stock one or can they put a aaftermarket one on? which should I do? will the new aftermarket one have a electronic wastegate?
Old Feb 4, 2008 | 09:46 PM
sallyman1's Avatar
Can you clamp off wastegate with visegrip? on electronic ones?
Old Feb 5, 2008 | 12:23 AM
53 willys's Avatar
build one of these if you wanna check for leaks......https://www.dieseltruckresource.com/...ght=boost+leak
nother with a parts list.....https://www.dieseltruckresource.com/...ght=boost+leak
nother....https://www.dieseltruckresource.com/...ght=boost+leak
this one is in the FAQ section at the top of the page....https://www.dieseltruckresource.com/...n&onlynewfaq=1
abchoppers
Jan 26, 2011 05:38 AM
wilderness
Sep 16, 2006 10:14 PM
ASoldano
Apr 24, 2005 12:02 AM
Crimedog
May 25, 2004 09:18 AM
