How much is too much?
Old Sep 8, 2008 | 08:04 PM
Jason A's Avatar
Rail Pressure?
Just took my first run with the Xzilleraider 2 (stacked with BDTD CL).
Adjusting the levels and watching the RP I'm seeing anywhere from 17-18k (CL alone) to 21-22 k (CL + QZ LVL 5) crusing at 80.
So the question is, how much is too much (short term & steady 4-7 hour runs) for stock injectors?
BTW max WOT was around 26-27k. Of course this makes sense as the (stack) race tune on the QZ sets a max at 27.5k.
Also, is the max RP set at 27.5 for the normal race?
Thanks
Old Sep 8, 2008 | 09:21 PM
coreydr2003's Avatar
Do you have a modied pump or is it stock? What does RP do if your tuner is on lower levels, I wouldn't run the tuner much over stock if just normal driving for hours. Those # are about right, even at wot, just would like to know if you have a stock pump or not
Old Sep 8, 2008 | 11:00 PM
Jason A's Avatar
Thanks, wasnt sure. Been running the CL for a while without any idea of the RP. Happy to hear I'm in specs.
RP is running around 650-700 at idle w/wo CL. havent taken iyt all the way down but had it (BDTD) on performance and still was running around 16-17k at 80.
As far as the pump goes I've still got the stock CP3 with a 30psi AD100.
Havnt decided if it runs better with the QZ stack (pressure only) or with the regular tune with timimg.
Only had the regular tune on it for 1 day before I loaded the stack but first impressions feel like it doesnt seem to have as much oomph with pressure only.
Old Sep 8, 2008 | 11:50 PM
thats prob cuz of the stock pump,
dieselJon
Jan 3, 2011 08:18 PM
jjrightmire1973
Nov 20, 2008 08:20 AM
Lu
Jun 24, 2003 08:57 AM
Wes C
Dec 24, 2002 12:28 AM
csaverline
Dec 8, 2002 07:18 PM
