How much for t/c and V/b installed
Old Feb 27, 2007 | 08:41 PM
Kevin Krieger's Avatar
I was quoted for a dunrite T/c and v/b single $2725 installed. Is this about right and would this be a good setup? I live in Oregon and need a local shop for install.
Old Feb 27, 2007 | 08:48 PM
boarbuster's Avatar
It also depends on how bad, if any, yours is burnt up. When mine was done it was burnt up pretty bad so i had to have a lot of internal stuff replaced.(clutches, bands, thrust washers, etc.)
If it isnt messed up then that sounds like a decent price but you never know until you get inside of it.
Also, the more billet you can afford the better.
Old Feb 27, 2007 | 09:32 PM
Lark's Avatar
Torque Converter: $1,295
Valve Body: $475
Flex Plate: $475
Input Shaft/Hub: $650
Intermediate Shaft: $650 (optional if not drag racing)
Output Shaft: $650 (optional if not drag racing)
Installation (Goerend): $500
Old Feb 28, 2007 | 07:34 AM
omaharam's Avatar
Guys
That's not what he asked. he only asked about a TC/VB install. Dave Goerend isn't close to you but he gets
1295 triple disc
450 vb
400 labor
If I'm not mistaken. That is only $2145. So $2725 sounds way too high - especially for a single disc.
Old Feb 28, 2007 | 07:03 PM
Thanks guys. That bid was from rip at source automotive anyone know another good shop in Oregon. Would it be ok to buy from dave goerend and have someone local do the install? Or am I just going to have headaches trying to have another shop install goerends products?
Old Feb 28, 2007 | 07:35 PM
omaharam's Avatar
I know last year he was trying to find a few shops that he felt comfortable doing installs for his stuff. I would call and ask him if he has anyone in your area.
Old Feb 28, 2007 | 07:56 PM
mickey5978's Avatar
Get the input shaft as well. Dont want to mess up the high dollar convert if it snaps.
Old Feb 28, 2007 | 08:04 PM
omaharam's Avatar
He doesn't even have any power mods. So unless he plans to go big on power, he doesn't need to spend an additional $650 plus labor.
That is another benefit of going with Dave as well. His 3 disc with lifetime warranty is unconditional. If the input shaft breaks off in it, he still replaces it for free.
Old Feb 28, 2007 | 09:02 PM
I just sold my flashpaq and am going to purchase a smarty and run it on 3. 5 at the max. Do I need the billet input shaft?
Old Mar 1, 2007 | 06:27 AM
omaharam's Avatar
Originally Posted by Pull U 2
Right now I only use the Juice w/ Attitude but I figure that with the bigger tires, towing and off-road it's good insurance and cheaper if I do it all at once. I see you run 35's and the Smarty makes more power then the standard Juice so it may be something for you to consider. JMO
The SMARTY on my truck made less power than the HOT Juice. I am only running a TC/VB. The SMARTY on 5 isn't going to require a billet shaft. But, it's not my truck and I'm not responsible if it breaks.
Old Mar 1, 2007 | 07:28 AM
Lark's Avatar
Dave highly recommends the input shaft. The other two shafts are optional depending on drag racing. This is straight from Dave on the phone.
1$Chuck
Jul 15, 2011 05:00 AM
Mr. Roper
Feb 12, 2009 10:18 PM
silkywoods
15
Aug 30, 2007 07:03 PM
rjm022
Nov 23, 2006 11:29 AM
boughtadodge
Jan 2, 2003 08:15 PM
