How much Power Service can I run?
I will be dynoing on winter fuel tomorrow, and am wondering if all you smart people can help me with how much power service to add to my fuel. The bottle says it raises cetaine 3 points in 100 gallons and 6 points in 50 gallons. Can I add the whole bottle to 30 gallons? I know at a point you can't raise the cetaine number any higher and that at a point it doesn't need to be any higher. Kind of like those people that run 92octane premium gas in a car that only requires 87octane. It doesn't actually add any performance. So is a whole bottle ok, or should it be less or more?
Thanks
Thanks
I doubt it would hurt anything to use the whole bottle in 25-30 gallon tank of diesel, but like you said at some point there is no real gain.
I have added about double the 6 cetane amount to tanks going to the track, don't have a clue if it helped or not.
This might surprise some people, but I've always filled the filter housing with pure Power Service when I replaced the fuel filter on my old 2000 Cummins. It always started up promptly, no difference in start- up noise, and ran smoothly.
I sold it recently at 171K with never a problem with the VP44, injectors, or fuel system.
I don't believe putting in more than the recommended amount will do any harm or do any more good! Anything past 16 oz in a tank is probably just wasting money.
I have a friend whose a heavy duty diesel mechanic. He worked for a company that ran a lot of light duty, medium, and heavy duty diesels. He told the drivers to put in FPPF every fill. He swore by using a conditioner to save those pumps and injectors.
Totallyrad
Jul 19, 2011 07:41 AM
Common
25
May 21, 2007 12:29 PM
SSminnow
Dec 31, 2005 09:35 AM
