how many quarts of fluid for the 48RE?
Old Jun 16, 2008 | 11:17 PM
jwb600's Avatar
ok I drained my fluid to do a filter/fluid change on my transmission. its a 48re auto with a double deep mag-hytec pan. I didnt drain the convertor just took the pan off to get to the filter and drained the pan and cleaned it out. I looked for other threads before posting so ive got a couple different answers. I know the deep pan adds 4 more quarts to the capacity I just dont want to overfill it is why im asking. thank you for any answers
Old Jun 17, 2008 | 12:00 AM
jwb600's Avatar
I put in about 9 quarts or so and quit for the evening. I was told about 20-24 but I think that is if the tranny is completely empty along with the converter
Old Jun 17, 2008 | 10:24 AM
jwb600's Avatar
anybody got an answer?
Old Jun 17, 2008 | 10:51 AM
ptgarcia's Avatar
9 quarts sounds about right. I have the non-double deep Mag pan and after draining the pan and changing the filter it took 6 qts to fill it up to the high side of full.
Old Jun 17, 2008 | 11:20 AM
paroxysym's Avatar
um it took me about 13-15 i want to say and that was the stock pan. completely drained.
Old Jun 17, 2008 | 12:43 PM
jwb600's Avatar
ok guys thanks for the info it is greatly appreciated
Old Jun 17, 2008 | 01:00 PM
paroxysym's Avatar
run to walmart, and grab yourself 15 qts. i want to say i used about that. since my converter came filled from dave already.
Old Jun 17, 2008 | 01:21 PM
TexasCTD's Avatar
That is about right, with a MH double deep pan and you are only draining, dropping pan, replacing filter, reinstalling and adding back the lost fluid.
Old Jun 17, 2008 | 01:22 PM
TexasCTD's Avatar
Since you have a built trans can't you drain the converter too?
Old Jun 17, 2008 | 03:12 PM
Moobesor's Avatar
Completely drained I put in 19 quarts. I have a deep ATS pan. This includes filling the torque converter.
I would say 16 quarts if torque converter is full. Depends on the torque converter, too.
Old Jun 17, 2008 | 03:17 PM
paroxysym's Avatar
sounds about right..
Old Jun 17, 2008 | 07:46 PM
jwb600's Avatar
well Im not master mechanic and never claimed to be. I go drive it some and try and get it warm then check it running in neutral like it says then it will show OK then I put the stick back in and its showing nothing. its little dumb stuff that holds me up. I talked to marianne @ hts and she said 20-24 and I know it filled my drain pan up when we drained it. they know more than me but that sounds a bit much. I guess I better keep adding some fluid and just keep checking it.
Old Jun 17, 2008 | 07:49 PM
jwb600's Avatar
I had some extras but I bought about twenty or so quarts at meijer. I like to have extras just in case. I hate going to the store anymore I would rather just buy extra and have it around. thanks for the help
Old Jun 17, 2008 | 08:35 PM
GlennRMK's Avatar
When I did the valve body with standard pan I put in 10 quarts.
Ram95
Nov 17, 2010 09:56 AM
fatpete
Nov 11, 2010 05:55 AM
eliminate this
Dec 19, 2008 10:13 PM
04ctd
Aug 4, 2008 11:41 PM
Common
Apr 7, 2008 08:30 AM
