View Poll Results: what do you want your egt's at before shutting down??
around 300 and below
30
28.57%
301 to 325
21
20.00%
326 to 350
17
16.19%
351 to 375
14
13.33%
376 to 400
10.48%
400 and over
0
0%
I don't care what the egt's are
2.86%
what are egt's
0
0%
I like donuts
4.76%
click if this is a dump poll??
3.81%
Voters: 105. You may not vote on this poll
How low should your egt's before
Old Feb 23, 2007 | 03:32 PM
madhat's Avatar
Administrator/Jarhead
Around 300. My EGT's cool off pretty quick...
Old Feb 23, 2007 | 03:46 PM
DADDY'S DIESEL's Avatar
SO who likes donuts
who does not care about their egt's
and who thinks the poll is stupid???
Old Feb 23, 2007 | 03:55 PM
drodgers's Avatar
Originally Posted by WHITE3500DUALLY
SO who likes donuts
Not a donut fan. Unless it's asphalt donuts.
You bet I care about egt's.
Nope, it's a good poll. We can see how many actually post in the over 400 and don't care options.
Old Feb 23, 2007 | 03:58 PM
RamWheelsBy4's Avatar
never heard of cool down timer or a turbo timer
is yours the P7100 Shutdown Solenoid Kit from TSTproducts.com
The latest TST PowerMaxCR R49 has built in turbo Cool Down Timer function. Can be set to EGT and/or Minutes(1/10 increments). It is a great feature that is just a bonus along with all the power.
Old Feb 23, 2007 | 04:32 PM
own1bigtruck's Avatar
Well i like donuts, but i guess someone beat me to it. I was trying to be original. As far as my egts, I couldnt tell you yet since my gauges arent here yet, but i usually let it idle for about 5 minuts before shutdown
Old Feb 26, 2007 | 12:32 AM
dodge2005's Avatar
Usually 300 degress but I do like donuts.
Old Feb 26, 2007 | 02:52 AM
morkable's Avatar
There is no need to let it cool to 300, honestly anything below 400 is good. And with a good aftermarket turbo even that is less needed. The reason to let the egts cool down is so that oil wont coke up inside your turbo, which will cause in a turbo that has lesser tolerances to wear. But the oil doesent really coke up unless you are pushing it hard and have it to an allmost boiling point. When you have pushed it hard, say around 1000* or more for an extended period of time, not only is the oil red hot, so is the turbo.... so now if you were to shut it down to early (say at around 5 or 600*) the turbo would still be hot, and so would the oil. This will then cause coking inside the races of the turbine wheel. But if you havent pushed your turbo hard, so lets say you were cruising around, and your egt's were around 800* and you stop, usually that means you were just taking it easy, the turbo wont have the heat permeated as deep into it,, hence it takes way less time to cool the turbo,, also the chances of coking are greatly diminished... So I guess what I am trying to get accross with all this ramble is that by the time your turbo has reached <400* there is little or no chance of coking, all the heat from the turbo will have disappeared. Leaving it to 300 or less is just a monumental waste of fuel, and will not have any positive value for your turbo, and if anything will decrease the life of your engine slightly from excessive idleing. I have a turbo timer that is based on temp, I have it set for 350, but I dont have any problems shutting down anywheres between 350 and 400
JMHO
Kevin
Old Feb 26, 2007 | 05:38 AM
4x4not's Avatar
I have a BD Turbo timer which is temp based. I have it set around 300
Normally it only takes 30 seconds to shut down unless I've been towing or running it hard.
Old Feb 26, 2007 | 07:07 AM
tcr's Avatar
tcr
I don't know how you guys get it to 300*?? My 2 egt probes must both be off, I never see 300* even if it idles for 10-15mins. I beat the @#$% out of my last turbo, 1600*+ pulls and the wife shut her down HOT all the time. When I pulled that turbo, the internals were in perfect condition, no caked on anything. I couldn't believe it w/ 87000 HARD miles on it. I think these turbos are a little more resilient than most of us think.
Old Feb 26, 2007 | 10:16 AM
morkable's Avatar
That is exactly what I was trying to get accross tcr. Going down to 300 is a monumental waste of fuel. When I changed my turbo on my truck I looked at the stock one, I had pulled heavy with it, didnt have a pyro, and same thing wife would shut down hot all the time. And after 60k miles it was still perfect, no signs of any damage whatsoever
Kevin
Old Feb 26, 2007 | 10:53 AM
tcr's Avatar
tcr
I'm saying I can't get there, not that it will take forever. I agree w/you totally, my truck must just run hotter than most I guess.
Old Feb 26, 2007 | 01:33 PM
Jfaulkner's Avatar
Muted User
Kevin
My feelings exactly! There are people on here that refuse to shut their truck off at a drivethru (i.e. McDonalds) and have to repeat their order 3 times ONLY because the pyro isn't at that magic 300 or 350. Now don't get me wrong, I don't care if you ever shut your truck off. But it seems to me the people on here that are "cheerleaders" (for lack of a better term, no offence intended) on how tough the Dodge Cummins is, are the same group of people who insist on using a special type of oil and/or filter to prevent catastrophic engine damage, 2 micron fuel filters to keep injectors from dying. Pusher pumps to keep injection pumps from dying, extended idle times to lower EGT's to special numbers. I mean come on guys as much as I like my truck if it takes that much special attention to stay alive........ Most women I know don't require that much maintaince.
desertchecker
14
Feb 18, 2008 09:32 AM
jmccart
14
Nov 20, 2006 06:45 PM
04.5HO600
Jun 29, 2005 08:59 AM
Stamey
Jan 8, 2003 07:45 PM
